Nortel IP phones going to server unreachable even when the connection for cascading to the PC for the network is working.It goes to the NODE then TN and suddenly it displays server unreachable takes time then to the NODE again TN and the circle continues
Many small businesses, when just starting out, try to save on such systems and buy small voip systems without additional professional functionality. Although I think this is a mistake. Since a small business quickly outgrows the phase of a small number of calls into a large one. Especially in your case. Connect phone systems for small business https://1voicetech.com/solutions/small-business from this company. It has all the features you will need.
Our company is in the business of setting up equipment and providing advice over the phone. We have hundreds of calls a day, now we use a small VOIP system. But the number of calls is already overwhelming the available pool. We need to look for an alternative.
SOURCE: server unreachable
go to menu --> settings --> network configuration --> server menu and scroll down to server address and give the server ip address and save the settings and reboot
SOURCE: Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
SOURCE: Nortel i2050 doesnt connect for different VISTA users
my i ask you say you are trying to login to the phone why?
when you say you but them on to a new tn did you put both ext back on the same tn
Same problem - different model of phone (still Nortel) after 1'30", phone says server unreachable, then reboots - and then connection is re-establised.
