20 Most Recent
2wire (1000-400108-001) Router Questions & Answers
I can not download netflix
This is a problem with the connection not the Roku. Also things that can effect this is now many Movies you have in your Netflix Instant Que. Deleted some of the Instant Que movies and reboot the Roku. See if this will FixYa up.
12/28/2018 3:34:42 PM •
2wire...
Answered
on Dec 28, 2018
Att 2wire wireless and dlink
the only thing you need for connecting 360 to wireless is an Internet connection, an 802.11G wireless router, and a wifi adapter that connects to your 360. They have these at walmart or any gaming store. I suggest giving your 2-Wire back to ATT! NOT QUALITY. Especially for gaming.
I myself prefer my box to be hard wired as lag is far less. BUT..for wifi
Get a Linksys Router and XBox brand wifi adapter for 360. Also google xbox connect. Instead of paying for LIVE
James Mac
4/6/2018 6:56:21 PM •
2wire...
Answered
on Apr 06, 2018
I have an AT&&T 2701HG-B Gateway 2Wire
there is an adaptor that you can buy
it is plugged into the power socket for the house , connected to the ether net connection
you have a second plug in connection that plugs into any other power point and that runs a ethernet cable to the pc or modem
I have such a system running from the shed computer to the house computer and modem distance of 100 yards
it is called a TP-Link and is available fro Jaycar or like electronic shops
it works by using the house wiring to transmit the data signal along with the house power
3/23/2017 2:46:33 AM •
2wire...
Answered
on Mar 23, 2017
Hard reset for 2 wire router 1020
If you do a hard reset on that sort of router, any information on the router will be lost, and the router will return to factory defaults.
Do you mean that you want to do a hard reset on your FRIEND'S router, so that you can go back to using the OTHER router that you lent him?
look for a small, recessed button on the back, near where the power cord plugs in. you'll probably need a pen or sharp pencil in order to press it.
if you can find that recessed button, hold it down until the lights on your router blink
simultanously, then release it. I know that works on SOME models of 2Wire routers, I'm not certain whether or not this model has the option or not.
7/2/2014 9:56:32 AM •
2wire...
Answered
on Jul 02, 2014
My 2wire 1000Hw router keeps restarting
I have had three of these do the same thing. It is not the router causing the issue. It Is the power supply. I replaced mine with one from MPJA. It is a 4 Amp supply and I had to change the connector but total cost is $6.95 plus shipping on the power supply and $2.00 for the connector. Specifically inside the power supply is a 1000 uf cap that is bad and leaking. When the wifi and the DSL are both started the current is too high and the voltage drops causing the reset. Replacing the power supply fixed all three modems.
3/29/2014 11:49:57 AM •
2wire...
Answered
on Mar 29, 2014
Change network name (SSID)
Is this an ATT U-verse and you have TV on a different box? if so you will need to contact them. If you had to have the router replaced they forgot to re setup the system as the two devices work off each other somehow.
3/26/2014 5:02:44 AM •
2wire...
Answered
on Mar 26, 2014
2Wire router keeps dropping connection
if you try to change the router and getting same problem, i think you need to isolate it first without the router because this is not the issue, by the way did you ask your ISP to run a line test? what is the result? have you try to change the modem? my first suspect is the modem.
1/22/2014 7:24:17 AM •
2wire...
Answered
on Jan 22, 2014
Forgot my password to login ussing 2wire473
If you want to reset the router meaning bring the router back to its default settings and also clearing the password, you need to press and hold the reset button on the router its a small hole there and you need a pen or paper clip to reset it for 15 seconds while power is ON and after that router is already reset back to default.
1/17/2014 7:41:21 AM •
2wire...
Answered
on Jan 17, 2014
