I bought it open box at Walmart. I called Sony customer service and they told me to hold down the eject, play, and stop button at the same time until I see "TLK OFF" and it never appeared on the screen. Now the Sony Tech says to return it to the store, that it's defective. Any other things I could try to get it working?
SOURCE: Sony BDP-S300.
I had the same problem and sent an email to Sony. Here's the answer (it worked) :
Go to page 53 of Operating Instructions Manual and reset the player as indicated.
If you do not have the manual, here's what to do : Press Power On button. Power On light will come up. Now, Looking at front panel you have (at right side) 5 switches : Play, Pause, Stop, Rewind, and Fast Forward. Stop is the center switch.
Now, with Power On light on (it lasts only about 30 seconds), HOLD DOWN the STOP button and PRESS POWER ON button (the power on light has to be ON). This will reset the player. It worked with mine one.
Jay
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
SOURCE: sony dvd tray locked
had the same prob with a sony dav dz it kept saying locked but after hours and hours of pressing random combinations it came off im sure it was unplug plugback in then hold power and open tray and tap stop or a combination of those buttons.i woud try it again on mine to make sure but i do not want to lock it again.
SOURCE: DVD player disc tray won't open
loader mechanism has malfunctioned and is not user serviceable at a reasonable cost. replacing this unit would be your best bet
SOURCE: my sony dvd player will
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control.
NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode.
Each time this procedure is performed the disc tray will either lock or unlock.
