20 Most Recent
Sony BDP-S3200 blu-ray/DVD player with WiFi Questions & Answers
Eject key unavailable on sony blu ray bdp-s3200
You may have seen this answer before on the sony support page and tried it with no luck, but the following DOES work. The trick is that you have to do it for a LONG TIME (I didn't time it, but it was maybe twenty seconds or so):
Hold down the EJECT and POWER buttons on the dvd player simultaneously, until you see a message that says DEMO MODE OFF (or something similar to that - I forgot to write the exact message down). When you see that message, let go of the buttons, and the tray will eject/open. Again, the trick is that you have to hold both buttons down until you see the message appear on the screen.
Hope this helps.
How to connect player to a tv with no hdmi port
The old fashioned way ofcourse. Use the three pin RC lead. The one which has a red, white and yellow connectors on each end. yellow is video, red and white are for each audio channel.. Left and Right.
How can I fix my Sony Blu-Ray player BDP-S3200 with the Eject Key is Unavailable problem?
Try the following: Demo mode locks the tray like child lock
The tray lock should toggle on and off . While the player is turned on, press STOP, HOME, and then TOP MENU
button on the remote to lock or unlock the tray.
Note try by pressing STOP and HOME together then TOP MENU
To get a disc out
1 Turn the player off, and disconnect the AC adaptor.
2 Reconnect the AC adaptor while pressing down (/\ underline)on the player.
3 Keep pressing down (/\ underline) on the player until the tray opens.
Also try resetting - Reset to Factory Default Settings
Good luck
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
