I just moved my Danby portable washing machine down a flight of stairs.(We did so carefully!) It no longer advances through the cycles. Each cycle still works, (filling with H2o, spinning, draining, spinning) but I have to advance the knob to each new cycle myself. It doesn't work automatically.
Is there a way I can re-adjust it to work properly?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
My Danby DDW1805W 18" portable dishwasher is less than 3 years old. Timer Cam no longer will advance. Contacted the Danby company. Turns out they've changed the design of the front door panel controls and no longer produce, nor have in stock, the old timer cam that I need. The new door panel/controls are not compatible. $359 wasted. A new Danby dishwasher costs $400 at Walmart. Danby won't give me a "rebate" towards the purchase of a new Danby dishwasher, no price adjustment, nothing. Basically they told me I'm just plain out of luck. I'm not the only person with this same problem DO NOT BUY DANBY.
