SOURCE: Dremel 395 Type 2
hello,
try to find it here:
http://www.powertoolspares.com/parts2.php?model_ID=3057
may this help.
melnavz
SOURCE: Dremel Model 395 Type 3 Plastic Drive Shaft
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
SOURCE: I own a Dremel model 395 type 5 variable speed and
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
SOURCE: My Dremel tool has intermittent power.
You can go to any repair facility and buy a replacement cord making sure of the wire guage and conductor (2 or 3) what you can do is make a wiring diagram and remove the old cord and holding the cord about 10 inches from end pull one wire at a time and if there is a break it will pull out to confirm your suspicion. Let me know if you need any more help and if I have answered your request would you please rate this response accordingly and thank you.
SOURCE: My Dremel 395 type 4 does not run until I spin the
Sounds like a switch or brushes. You can go to Dremel.com and they have a toll free number for their tech services and you can also download a breakdown for this tool.
