Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
You need to make sure the brake switch is working. wiring to the switch needs to be checked. also to find out if the inhibit is broken in the charger disconnect the white flat plastic plug connector to the controller. turn off then on try it. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: batteries do not charge but charger is working.
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
SOURCE: Hi, fitted my scooter with two brand new 40 amp hr
What type and what voltage were the old batteries removed from the scooter?
Testimonial: "Thank you for the help, - the link didn't work but i'm slowly getting to understand things now."
SOURCE: I have a rascal mobility scooter, TE 388EMI have
Hello, i work for Electric Mobilityand we manufacture that model of scooter. If you call 0800 252614 you can speak to a member of the customer service team who can help. Different bleeps mean different things. Alternatively, you can take the scooter to your local retailer to be serviced - call our customer service department on the number and they will be able to point you in the direction of your nearest stockists. Hope that helps.
got new batteries after finding they hadnt been charged for a long time & were ruined charger did work before being left.
is the front gauge going up when you plug in the charger, by the way which wires are you talking about, the ones that go to the flat white plug or...?
