NEC Versa LX Notebook Logo
A
Anonymous Posted on Apr 19, 2012
Nec i select m5210/ fm5210 keyboard part number
Please could any body tell me the part number of the keyboard for a nec i select m5210/fm5210. the keyboard is missing on the laptop i was given
1 Related Answer
Anonymous
  • 6 Answers
  • Posted on Feb 12, 2010
SOURCE: USING WIFI DID NOT HAVE POWER HOOKED UP. WARNING
Plug your power cord back in, then boot your computer again. If your WiFi button was on before, it should automatically switch on after booting your laptop.
I could not find any information as to where the WiFi switch is located on that model, but it should be near the side, front, or near the keyboard. It should be a small switch or button with this symbol:
http://www.webstercounty.lib.mo.us/wifi%20logo%2001%20web.jpg
Hope that helps!
If you need any more help,
Contact me at [email protected]
Why is my nec i-select m5210 just says acquiring network address taking too long
Try to turn off your modem/router for 10sec and restart it and then try to connect. Hopefully it should work. If it doesn't then try to reset your router.
1helpful
1helpful
Nec i select m5210 upgraded to windows 7 i need a video controller diver that is compatible
just download this software,no need search engine,no more tired of looking anywhere...instantly,it will be in your laptop for several minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
I just install XP on my laptop, it is NEC I-Select M5210 put no sound. I try realtek but it wont still work. PLZ help. am out of options here
this may not supprt ur system hardware..then u hv to insert the driver n utilty disk given by ur notebook company ...then install the realtek 4 ur hardware...........hop it help u
I have a nec i-select m5210.i dont know if the battery is dead or the laptop wont recognise it.if it is dead what is the no. of the battery i need
you can go on ebay and get a battery for an nec m5410, they are the same
Does the battery in an nec m5410 work in a nec 5210? I have an nec m5210 computer and need a battery, it looks like BATTERY FOR THE M5410 may work but i want to certain before i order from ebay HELP!!!!!!!!!!
  • 1 month ago
Report Abuse
1rvtbxww4aaeb_mhf9vk=.medium.jpg by DavidG Member since:07 June 2008Total points:15365 (Level 6) Best Answer - Chosen by Asker Yes they are the same - the part codes SQU-510 and SQU-527 are compatible
  • 1 month ago
USING WIFI DID NOT HAVE POWER HOOKED UP. WARNING OF LOW BATTERY THEN SHUTDOWN. THREW WIFI BUTTON OFF. HOW/WHERE DO I SWITCH IT BACK ON ? NEC i-Select M5210/FM5210 LAPTOP
Hope that helps!
3answers
5helpful
2answers
Keyboard keys that have purple numbers are locked. Can't type.
Your "Num Lock" is on.
Look for the num lock key (it's similar to the "caps lock" key in function)
If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Nec i-select m5210 / fm5210 screen
any 15 inch screen should fit it, its the inverter thats mainly differant, the part number you require is B150XG0
hope this helps
PS if you want to sell the laptop as spares let me know cheers
http://martinjones.eu
2answers
Device drivers for Nec i-select M5210
go to microsoft.com and enter your vista model no(i.e)that is the no you mentioned(nec i-select)......you will definitely find the required drivers in that site.[but please enter enter your no correctly...otherwise you will find different drivers...].Try this it will work 100% for you.
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
