20 Most Recent NEC Versa VX Notebook Questions & Answers
2answers
Will not start
Try this fix...you will need your windows installation disc for the fix.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
12/16/2018 11:45:40 AM • NEC Versa VX... • Answered on Dec 16, 2018
2answers
Dear Sir, I got nec Versapro
There is a few different ways you can do this:
Search google for NEC Versa VX PC Notebook Audio Drivers
or
Go Here: http://www.gzrcw.net/drivers/nec/s820/drivers_1469.html
5/8/2017 6:32:55 AM • NEC Versa VX... • Answered on May 08, 2017
Driver nec versapro vy10/c 3
http://search.casnavi.nec.co.jp/support/pc/module/sabun/enterprise/200705/versa/0705vve2.exe
5/8/2017 6:22:47 AM • NEC Versa VX... • Answered on May 08, 2017
Sir mere pash ek nec VersaPro vj11f/bh-t ka laptop
http://search.casnavi.nec.co.jp/support/pc/module/sabun/vista/200605_07/versa/0510vvi6.exe
5/8/2017 6:16:18 AM • NEC Versa VX... • Answered on May 08, 2017
( Versapro VY13M/LX/U ) need to dawnlouad drivers
go to folowing link you will find your drivers
http://www.general-search.com/download/versapro-vy13m-ex-u-audio
please vote me if you get your solution
5/8/2017 6:13:06 AM • NEC Versa VX... • Answered on May 08, 2017
7answers
NEC VersaPro VA10h audio Driver Download
hi
i need graphic and sound card
NEC VersaPro VA10h thanks alot
3/19/2017 4:25:30 AM • NEC Versa VX... • Answered on Mar 19, 2017
2answers
Where can i download the drivers for my NEC
Start at www.nec.com, click 'Support and Downloads', then 'Downloads' on the next page.
5/25/2016 4:18:15 AM • NEC Versa VX... • Answered on May 25, 2016
How do I connect NEC versa Lx laptop to my dsl internet?
26200362-0w21o0w50atiexqhyc4a2yh0-1-0.jpg You need one of these PCMCIA network adapters. The one shown in the picture above requires an adapter cable (supplied when new) that connects the card to the ethernet cable. other later types of card have the socket on the card. 26200362-0w21o0w50atiexqhyc4a2yh0-1-1.jpg
5/21/2016 2:36:21 AM • NEC Versa VX... • Answered on May 21, 2016
2answers
Software
here's the link to NEC support and downloads for drivers and manuals
http://www.nec.com/global/support/
hope this helps
1/26/2015 7:29:19 AM • NEC Versa VX... • Answered on Jan 26, 2015
3answers
Vy22x video driver
You can download drivers from the NEC WEB site.
Please click on this link and select your model notebook and the
Windows XP or Vista drivers you require :-
www.nec.com/global/support/downloads/index.html
1/26/2015 7:11:33 AM • NEC Versa VX... • Answered on Jan 26, 2015
3answers
Where will i download NEC Versa VX PC Notebook audio Driver Download
I have lost my audio drivers after formating my nec versapro vy10F notebook. where an I get the drivers?
1/26/2015 6:46:19 AM • NEC Versa VX... • Answered on Jan 26, 2015
6answers
I CANNOT FIND THE DRIVER
I CANNOT FIND THE DRIVER OF NEC VERSAPRO VJ11F/BH-T
1/25/2015 9:55:26 AM • NEC Versa VX... • Answered on Jan 25, 2015
Drivers for NEC Versa Pro VE-6
http://search.casnavi.nec.co.jp/download/pc/module/sabun/win7_Versa_index2.htm#200800_versa
11/13/2014 7:39:32 AM • NEC Versa VX... • Answered on Nov 13, 2014
Driver driver nec versapro vy10a/c-4
http://search.casnavi.nec.co.jp/support/pc/module/sabun/200710/versa/0710vxp5.zip
11/13/2014 7:34:40 AM • NEC Versa VX... • Answered on Nov 13, 2014
Driver driver nec versapro vy10a/c-5
http://search.casnavi.nec.co.jp/support/pc/module/sabun/200805/versa/0805vxp5.zip
11/13/2014 7:30:35 AM • NEC Versa VX... • Answered on Nov 13, 2014
Vga driver versapro va12h
I will give you a easiest way for finding the drivers that you needforyour hardware.Just download the software named drivermagician.Installit and it will search for the drivers that is notinstalled for thehardware you have through internet and will downloadit for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
8/22/2014 11:58:26 PM • NEC Versa VX... • Answered on Aug 22, 2014
NEC Versa VX Notebook Logo
296 questions posted
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Versa NEC
  • Versa NEC
Most Popular Question
nec versapro va10h audio driver download
  • Computers & Internet
