20 Most Recent
NEC Versa LX Notebook Questions & Answers
Trying to connect to internet cant find wireless & cant find a ethernet place either
The laptop in question does not have a place to plug in the ethernet cable. The laptop is not fitted with wi-fi or bluetooth adapters either. The best and cheapest way to connect this laptop to the internet is using a PCMCIA Card Adapter (type two or three as both are supported.) such as the product supplied by linksys. If yours is similar to the one in the photo then it should include a cable with the required network connection on the end. The "linksys" card you mentioned is no doubt the correct one, but minus the vital cable!
Keyboardunlock functions
if your keyboard is a USB connect that you have to set USB ports enable on boot from mother board Bios setup. if not try another keyboard.if connected to Keyboard, Video Graphic card, Mouse (KVM) switch better to check the connection if every thing is right. boot the system and monitor the caps luck,numluck, light for flashing ones in during boot. if light flashes ones so extend wait time to let the drivers be loaded.
How do I boot from a usb on a nec versa lx laptop?
Go to the store and purchase a good copy of Windows XP and install it from a disk. In the BIOS you should have the option of booting from external devices as a alternative as well. This would mean USB or any plug and play drive. Make sure it is set to boot to this fist boot. Really I would just go and get a copy of Windows XP it should be relatively cheap now since there is no real support or at least it is dying out or has died for support updates. If you can purchase the original boot and software for your computer from the factory as well. I would also strongly suggest you take it in to the pro and have them do it less hassle for you if you have not done this a lot.
Computer keeps cutting out to
HI,
If you are getting a blue screen on the computer, it might be caused by 2 types of problems:
- It might be a Hardware issue, video card, sound card, memory, or hard disc drive.
- IT might be a software issue, a program like any antivirus, or office or other third party software that is causing this.
Have a technician check your computer for any issue.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Nec versa 4230: What is 4 pin adapter pinout ?
It is 13.5 v dc.
When viewing the end of the cable that connects to computer with the centered notch up, upper left and lower right are positive.
Upper right is negative (per the labeling on back of ac adapter),
I have a nec versa
Check first if the device has a driver. check as well if there's wireless switch button on the laptop.
How ro turn on the
there is a slide on off button on the lower lid right under the unlock slide catch when the lid is closed next to the mic and headphone jacks,push it to the right (on) then make sure you have it selected to search wireless networks in your settings if your running vista.
Serching for wireless switch on Nec Laptop
If You cannot enable 802.1x authentication on computers running
Windows 2000 because support for 802.1x is not provided by default in Windows
2000. Therefore, the associated user interface (the Authentication tab) does
not appear in the Network Connection Properties dialog box.
A supported feature that modifies the product's default behavior is now
available from Microsoft, but it is only intended to modify the behavior
that this article describes. Apply it only to systems that specifically
require it. This feature may receive additional testing. Therefore, if
the system is not severely affected by the lack of this feature, we
recommend that you wait for the next Windows 2000 service pack that
contains this feature.
The following files are available for download from the Microsoft
Download Center:
Collapse this imageExpand this image English Language Version
(http://download.microsoft.com/download/win2000platform/patch/q313664/nt5/en-us/q313664_w2k_sp4_x86_en.exe)
After you apply this update, follow these
steps to enable 802.1x authentication:
- Installing the hotfix installs the 802.1x service in the
disabled state. To change the Wireless Configuration service startup to Automatic: Right-click My Computer, and then click
Manage. Click Services and Applications, and
then click Services. Set the Startup value
for the service to Automatic, and then start the
service.
- Open Network Connections by clicking
Start, pointing to Settings, clicking
Control Panel, and then double-clicking Network
Connections.
- Right-click the wireless connection for which you want to
enable or disable 802.1x authentication, and then click
Properties.
- On the Authentication tab, do one of the following:
- To enable 802.1x authentication for this connection,
click to select the Enable network access control using IEEE
802.1x check box. By default, this check box is selected.
- To disable 802.1x authentication for this connection,
click to clear the Enable network access control using IEEE
802.1x check box.
- In the EAP type box, click the Extensible Authentication
Protocol type that is to be used with this connection.
- If you click Smart Card or other Certificate in the EAP
type box, you can configure additional properties if you click Properties and
then follow these steps in Smart Card or other Certificate properties:
- To use the certificate that is located in the
certificate store on your computer for authentication, click Use a
certificate on this computer.
- To verify that the server certificate that is presented
to your computer is still valid, click to select the Validate server
certificate check box, specify whether to connect only if the server
is located in a particular domain, and then specify the trusted root
certification authority.
- To use a different user name when the user name in the
certificate is different from the user name in the domain to which you are
logging on, click to select the Use a different user name for the
connection check box.
- If you click Protected EAP (PEAP) in the
EAP type box, your Windows user name and password are used for
authentication.
- To specify whether the computer should try authentication
on the network if a user is not logged on, if the computer or user information
is not available, or both, follow these steps:
- To specify that the computer try authentication on the
network if a user is not logged on, click to select the Authenticate as
computer when computer information is available check box. By default,
network if user information or computer information is not available, click to
select the Authenticate as guest when user or computer information is
unavailable check box.
What's the password for phoenix
try the following;
phoenix, PHOENIX, CMOS, BIOS
If that does not work you have two options.
1) remove all power and all batteries for about 15 minutes (there is a battery on the motherboard) and it should reset to blank.
2) if you can boot there are various bios hack programs to reset the bios but I would only do this as a last resort. I absolutely do not trust someone to hack the bios if I can avoid it. I’m happy to help further over the phone at
https://www.6ya.com/expert/thomas_b83e841f114394f4
