When i go to start/shutdown my pc will do everything to close and it closes down to a blank screen but the the pc is still running the fans are still running and if i hold the power button for more than 5 secs it doesnt shut down and i have to pull the power lead to shut the pc down also its not holding on cmos even tho i have replaced battery and done clear cmos
All these things point to the bios. You need to go to the Asus site for that motherboard and download an upgraded bios. There will be directions there on how to update your bios, probably both from Windows and from the system prompt.
hi thanks for the info but i have recently updated the bios to 1008/9 and i have just found out if i was to leave the pin set on clear cmos battery and start the pc it will start but if i was to put the pin set to default the pc will turn (fans only) and will not start unless i remove the pin set its well playing with my head
Don't feel bad--I've done the same thing!
SOURCE: cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies
If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
It is in your bios this motherboard has been known to have isues with the bios chip.I am useing this motherboard and have been lucky I did not get this problem you are haveing.You may try flashing to the curent bios 1903 geting the download from the Asus site.
Extract
Then remove file
Rename file to P5LD2.rom
Put renamed file only on three and a half floppy disk
Reboot Holding alt F2 at same time
flash will start
If you do not feel safe doing this then you can get a new bios chip from asus with the 1903
Good Luck
Also make sure you have no air gaps on your heatsink to proc this will cause the pc to heat up and shut down.
SOURCE: asus p4s533 will not boot after replacing fan + heatsink
Try to remove the processor, then clear it with contact cleaner, then plugin it again..
There isn't beep : Processor, and long beep is memory..
Hopefully this be of some help/idea..
SOURCE: P5RD1-V BOOT PROBLEM
The CMOS, which stands for complementary metal-oxide semiconductor, is
the hardware component of a computer that supports the BIOS, or basic
input output system. The two terms are often used interchangeably, and
the two technologies work together to perform the same basic function.
They maintain the low-level settings on a computer, letting the
computer know, even before the computer's operating system starts, what
kinds of hardware the computer has available, such as hard drives and
video display adapters. A special battery located on the computer's
motherboard powers the CMOS. To reset the CMOS on a Dell computer,
briefly remove and then replace the battery
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
