20 Most Recent ASUS P5AD2-E Deluxe Motherboard Questions & Answers
All these things point to the bios. You need to go to the Asus site for that motherboard and download an upgraded bios. There will be directions there on how to update your bios, probably both from Windows and from the system prompt.
ASUS P5AD2-E... | Answered on Apr 22, 2012
http://support.asus.com/download/download.aspx
select your product, series and models the click search you will find the driver you need at link above
i hope this helpful
thank you for using fixya
ASUS P5AD2-E... | Answered on Feb 03, 2011
CLEAN YOUR RAM WITH ERASER AND INSTALL IT AGAIN.IF NOT GETTING AFTER DOING THAT YOU HAVE TO CONTACT THE GOOD H/W ENGINERR.
ASUS P5AD2-E... | Answered on Nov 12, 2010
Clean the cooler on the top of the cpu.
If this not works...new cooling or change the thermal grease.
Get some cooler in the case to get a better airflow.
ASUS P5AD2-E... | Answered on Feb 05, 2010
Sounds like your BIOS is corrupt. In general, the only recourse is to replace the CMOS IC outright. You
could remove the IC and reprogram it in a EEPROM programmer. Or you could swap it out with a
similar motherboard. Or you could contact Asus and order a replacement.
ASUS P5AD2-E... | Answered on Nov 30, 2009
This is because the sound driver achitecture does not fit with operating system of windows 7. Search for the a sound driver that will be compatible with windows 7, that will be found in the website of the motherboard brand.
ASUS P5AD2-E... | Answered on Oct 25, 2009
This worked for me. You need the sound drivers for the "Intel C-Media High Definition Audio CMi9880".
I went to this sight www.softwarepatch.pl/plikd.php
Its in a different language but click on the box.
i downloaded the audio file called UDAX008(Logo56.62).zip.
Click on the box, and downloaded the zip file.
Unzipped it.
Then change the compatibility mode of the Setup.exe file to Winxp Sp3 by going to the properties of the Setup.exe file and click on the Compatibility tab. Check the box for "Run this program in compatibility mode for". And change it to Windows XP Service pack 3.
The drivers are actually meant for windows xp but they are working fine for me and im very happy now. I was worried like you. I hope it works for you.
w w w . s o f t w a r e p a t c h . p l / p l i k d . p h p
ASUS P5AD2-E... | Answered on Oct 23, 2009
Posting in caps is disrespectful so don't do it. Here's the link tou need fill in the details and download.
ASUS P5AD2-E... | Answered on Oct 10, 2009
the drivers may not be compatible with the mother board. Try goping to their website and get the correct driver.
ASUS P5AD2-E... | Answered on Sep 08, 2009
download it from below link:-
drivers.softpedia.com/get/.../Asus/Asus-P5AD2-E
or
www.driverstock.com
or
www.softpedia.com
ASUS P5AD2-E... | Answered on Jun 26, 2009
I have a P5AD2-E Deluxe motherboard,and not support the Vista audio
Please help me
ASUS P5AD2-E... | Answered on Mar 10, 2009
i have intel pentium4 2.2ghz dualcore and dell monitor . just i installed but i dont have any drivers for that. now my display is not clear it shows different like colours in whater and it showing mixed colour screen what can i do for this how can i solve this problem and i dont have audio drivers also how can i approch and which way give me some website names for audiodrivers
ASUS P5AD2-E... | Answered on Mar 04, 2009
Any PCI-express x16 board will work. It all depends on your power supply & budget as to what card you want. Check the AMD/ATI website for a list & specs of their cards. Nvidea also makes great cards. You can research for other manufactures based on the ati or nvidea chipsets. Hope this helps & please remember to rate my answer. Thanks.
ASUS P5AD2-E... | Answered on Dec 28, 2008
Normally 3 short beeps is MEMORY problem. Make sure the right memory is used and seated properly.
ASUS P5AD2-E... | Answered on Nov 25, 2008
Hi.
I could tell you exactly what Graphics Adapter to buy, but
i think is better if you learn how to decide by yourself, so i recoommend you to use the following url, that will take you to your motherboard Specs( you should always visit the manufacturers websites, because nobody can help you better than them).
Often you can get updated drivers for your devices from them.
If the link doesn't work, you can copy and paste the following address:
http://www.asus.com/products.aspx?modelmenu=2&model=404&l1=3&l2=11&l3=144&l4=0
In the Expansion Slots( the ones you use for graphics adapters) the performance decreases from top to bbottom.
I hope that help you
ASUS P5AD2-E... | Answered on Jul 12, 2008
ASUS P5AD2-E Deluxe Motherboard Logo
29 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
need audio drivers high
  • Computers & Internet
