Whenever I click for taking picture, camera's flash light does not flush.
SOURCE: taking pictures
This could be due to a jammed lens element preventing the camera from focusing properly. When you push the button the camera attempts to focus the image before it takes the picture. If the focus component in the lens is not moving properly it cannot focus and thus will not take the picture. Do you see the camera attempt to focus the image when you press down the button? If it does not make any noises when you push the button, and the camera does not attempt to focus the image then it is most likely a jammed or malfunctioning focus motor. This would require professional repair.
SOURCE: my camera doesn't work well because the shots were blurred
you probably have to change the mode...and adapt it for normal light cause it is on cloudy or low light ...and ts cause the picks to came out too bright almost unrecognizable
SOURCE: Wont take pictures with flash
The problem is in the battery holder of the CR1220
battery. -Take out the CR1220 battery (the little round one). -When
you replace it, put a bit of aluminum foil against the back, between the
battery and the plastic holder, to make it a nice tight fit. One layer won't do
it, but don't put in half the roll. -Put it
back in. Done Using a
fresh battery & clean it all with alcohol = good idea as well. Worked for me. Wich
