20 Most Recent
Hitachi i.mega HDC-401 Digital Camera Questions & Answers
My hitachi hdc-991e camera turns itself off after
It's bad/weak batteries. I had the same problem using Hyundai batteries, thought the camera had broken until I used Duracel instead and it worked as it should. Batteries don't last long in digital cameras full stop, but decent brands like Duracel will help.
Protected card on camera?
your card is probably locked take out the memory card and on the side is a lock tab slide the tab to unlock when you put it in your camera it may say format card when you do this it will format the card but will delete any pictures saved to the actual cameras memory so save them on your computer or print them.
My camera switches itself off
Sounds like weak batteries. Possibly a bad battery. May look good till called on then voltage drops fast. Cam goes off, before saving image. Replace batteris.
Its turns it self off when taking a picture
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
How do i transfer photos from sd card to camera on
1.Remove your SD card from the camera.
2.Insert it to your laptop card hole
3.If a window opens opens automatically then just drag and drop your photos to where you can find easily.
4.If a window does not open then click to My Computer
5. Find your SD card there.
6. Do the instruction number 3.
That is all.
LCD monitor switches on but lens fails to open and
sry this is not a solution but i had the exact same problem with my fujifilm finepix a900 and all of a sudden about a year later mine worked again. i would remove any mem stick/ cards u have in the camera and try with a different set of batteries, u may possibly have to update or reinstall the firmware on your camera and if none odf these thing word i can only offer u my puzzleing solution leave the camera lying arroun without batteries for a prolonged period of time month at least and try to turn it on i have no explanation as to why it worked for me but it did
