Televison & Video Logo
Ray Hummel Posted on Nov 21, 2006
No longer can change inputs on tv
Strange problem that apparently came out of no where yesterday. For some reason I can not change inputs on my ILO 26" LCD tv anymore. I can turn off the tv with the remote, and adjust the picture size, but I can't change inputs, change the tv volume, or bring up the tv menu using the remote or the buttons on the side of the television. Am I missing something here? My tv input is now stuck on component input for my cable box, but I am unable to switch it to any other input.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1202
Points
How do you even get into input mode?
madonna archer
Level 1:
  • Posted on Jan 10, 2007
madonna archer
Contributor
Level 1:
Answers
Questions
0
Helped
1202
Points
Mine did the same and i have been told that it is the mother board
  • wowiemia Aug 10, 2011
    if it s mother board, how do I get it fixed? as I cant use menu on tv's button or remote either, and I cant change the input, size of screen, and close captioned..all are not working. so what was the problem? I had it only 3 yrs....****** it~
Cant get my ilo tv to change the tv input with out tv remote
No. To select inputs, you must have its remote control.
I have no remote and can't change inputs
well most tvs come with a game in put that you can change on your tv menu but if you cant you will need a universal remote
Ilo 32HD NO Channels! buzzing noise
the input setting may need changed on your tv
3answers
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
I have a Mitsubishi Colour TV - old but lovely picture - Model CT25M2TX. For no apparent reason I cna no longer get BBC1 and IYV, and BBC2 shows not BBC2 but a strange letter/number combination. Channel 4...
I would like my £8 back as have received no help. have bought a new TV - so problem no longer exists! Your web site is somewhat misleading - as it made me think I would have help straight away.
ILO 26HD
The ilo tv 26HD turns off by its self after about 20 min. of being on.
Ilo
I have the same problem when using the coax hookup. try using another input and see if that helps, I no longer use the tuner, just hook my tv up to the inputs and set the tv on what I want to record, same with vcr tapes etc.
Can't record from tv or disc,
shouldn't need one, If you can't get the tuner source of your ilo to record, try using A/V cables (output) from tv to (Inputs) on ilo. set tv on channel you want to watch and it should come through to the ilo (selecting the correct source input of course) If your tv is really old and doesn't have A/V then you will need RF Modulator. This way of hooking tv up will also work with recording DIGITAL signal from a Digital converter box type tuner (the tuner in Ilo soon to be no longer operatable).
ILO 32inch TV
ILO 32" lcd hdmi tech support Eastern Time
8:30 am - 9:00 pm (monday through friday)
9:00 am - 5:00 pm (saturday)
1-800-428-1105
my 8 month old tv doesnt even turn blue. just blinking red light where on/off light display appears. very discouraged cause wallmart will not help. trying techsupport. i found this number from my purchase paperwork. hope it is helpfull to you.
32 in ILO tv, goes blank
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
loony2ns
Level 1 Expert
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
