Unfortunately, the only way to reach the AV input on the IWT3206 is with the remote's Input Select button. If your universal remote doesn't match that function, you need a different remote control. However, if the remote has a Source button, instead of Input, try that option or try programming the remote with any other codes for Funai TVs. The lowest end universal remotes often do not have bot the Menu and Input features. Other remotes may work better for your use. There are several sources that have remote controls that are guaranteed to match your original remote. At remotes.com, see http://www.remotes.com/SearchResults.asp?Search=IWT3206 . Amazon also has a matching remote: http://www.amazon.com/Replacement-Control-NE906UD-IWF2706-IWT3206A/dp/B009D5PC3S .
Ilo is a Sylvania brand and was manufactured by Funai. The manual is available here: http://www.funaiservice.com/manual2012_search2.php . (If you start at the Funai support page: http://www.funai.us/support/ , click on Sylvania and then select the Ilo brand and enter your model #.) The direct link to the manual is currently http://www.funaiservice.com/manuals/ILO/IWT3206/IWT3206.pdf .
I hope this helps.
The Ilo IWT3206 is a CRT type TV; it does have an ATSC tuner to support digital OTA TV signals. It doesn't have an HDMI port. The best input it has is the component video in. There are HDMI to component converters. However, most of them have issues with digital rights management protections (HDCP). The manual for the Ilo IWT3206 is available from the manufacturer (Funai). Their support page is at http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is http://www.funai-corp.com/support/om/IWT3206.pdf .
I wish that I had better news for you. If you have a different model, please post a comment or a new question.
About the only thing I can think of is getting a new remote that can accept the programming of the ILO TV and control it that way. A remote I use for work is a URC. They work great.
You might have pressed the 'Source selector' button; (AV) button. Just press that button again and again till the selected source appear as "TV'. Gopakumar Gopalan Google
made for wallmart by ILO
ILO TVs made in China. A few brand have been connected with iLo, are Funai, Orion, Tatung
ILO customer service number is 800-289-0980 or 1-800-939-0605
ILO TV Codes. 11286 11603 11684 11990
ILO TV. 0171 1286 1990 1603 0180 1271 1963 0179 0000 1004 1000 1950 1090 1090
