We do not have remote for ORION STV2555 27'' TV. How do we change TV to DVD mode using TV buttons. There is no TV DVD swap button on TV.
SOURCE: Get tv off of 16:9 ratio without original remote.
You must have the original remote. Do a search on the net for Orion customer support toll free number
SOURCE: Orion 27" TV - no sound
hi there, maybe you touch someting at the remote, try to experiment the bottons until it work, if still same problem, you have an amplfier section problem, test the speakers, some parts at the amplifier section. ty
SOURCE: I lost the original remote to my 27'' television
very sorry for that but you can be changing channel manually on the tv channel buttons, if you sweep on all channels you can go to AV from RF channels, that is before you buy a remote.
try to buy your remote from
www.ebay.com
SOURCE: Video Mode - Orion 27" TV - Model stv2555A
VICTORY! Had the same problem with my Orion model FTDV2004. Lost the remote and couldn't program a universal remote to change the input to AV. After a day of reading posts, I just started pushing the channel up button. Somewhere past channel 115 the "Line1" and "Line 2" inputs showed up.
SOURCE: rca 27'' tv set can't
Hello 1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked 2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked 3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds. 4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
Just unlock its FPA by any one of below mentioned process. Reset the V-Chip settings later and try.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
