My pump is hard wired and I had removed it for the winter. I have one wire (insullated Blk) connected to the switch, where does the other end of this wire go on the motor. I also have a white wire and a Blk wire (coming from my power box) does the white wire go to the switch, and from the swtich what terminal on the motor, where does the Blk wire connect.
SOURCE: air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
SOURCE: I have a 1988 Jacuzzi brand hot tub and I need a
Ekk, Jacuzzi went bankrupt in 2006. Best of luck to you.
SOURCE: it is an above ground pool. The Jacuzzi pump is 1
The cables will overheat if they are carrying more current than they are designed for.
There are two possibilities for this problem:-
1) there is a short circuit -not too likely as there would be tripping problem.
2) the motor is working harder than it was designed for and is drawing more current than the cables can stand.
Check the pump to see if it is rotating freely; perhaps there is something blocking the pump.
Which timer?: Wide variety of Pool and spa controls at Aplus
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://www.aplussupply.com/intermatic/timerpool.htm
If you need more help, re-post electrical details about your jacuzzi and exactly what you want timer to do.
