20 Most Recent AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Questions & Answers
A O Smith does not make a Pump,
they make motors, so...
what pump do you have, so pump rebuild kit can be recommended?
AO Smith 1 1/2... | Answered on May 11, 2015
WHAT IS THE PART NUMBER FOR THE IMPELLER AND THE MECHANICAL SEAL??
AO Smith 1 1/2... | Answered on Jun 27, 2014
Try posting in the correct area. It is a pump type motor but a I have no clue what a stamley 545 automatic gate is unless it is used to block access down a path or drive.
AO Smith 1 1/2... | Answered on Jun 18, 2014
Without model info, try this link. Most motor brands follow pretty standard wiring setups. Please rate me if this helps.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
AO Smith 1 1/2... | Answered on Apr 17, 2014
You need to find out what is causing the capacitor to short and "blow up or smoke". Then you will have to replace the capacitor again or the motor will never start up. Sounds like you either have a dead short or you bought a faulty Capacitor. Not uncommon for a 220+ volt Capacitor to be bad right from the factory. I replaced two Capacitors before I had a quality one, but after I replaced it twice I have had no more problems. Make sure to grease the motor through the grease fitting on it. The life of your motor depends on it.
AO Smith 1 1/2... | Answered on Nov 09, 2013
go to a motor store
AO Smith 1 1/2... | Answered on Nov 06, 2013
you need to know your load
try to have motor fix
be safe change the motor
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
98 questions posted
Top AO Smith Plumbing Experts
David Baisa
US Parts Center
US Parts Center
Lawrence Oravetz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
View Most Popular
AO Smith Plumbing
  • AO Smith Plumbing
Most Popular Question
motor not working
  • Plumbing
