1796-Sata Cabling Error
SOURCE: Audio Panel HP DC 7700 Minitower case with Hp 7600 motherboard
go to the manufacturer site and download the manual ...not just the schematic...in the manual you have the picture with the pin numbering ..and the functions .(places on the plug ..) and the wires are labeled
just change the placement of pin 7 to pin 4, but its only to solved the error massage, the front panel audio will not work properly
SOURCE: how can i install my
HI,
Installing the HP DC 7700 Drivers is a little tricky. You may have installed the drivers and its not working I guess. This is because the HP DC-7700 has HD Sound and it required "Microsoft Universal Audio Architecture Bus, which can be downloaded/ installed from the following link. Choose the Operating system you have on your PC and get the drivers.
HP DC7700 Drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Just download a driver online for free. Just click the link below:
Just click_here so that you will be redirected to the exact site. Just click on the download then follow all the prompts then you are good to go.
Thanks.
