20 Most Recent HP Compaq dc7700 PC Desktop Questions & Answers
As explained here
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=pl&cc=pl&taskId=125&prodSeriesId=3232028&prodTypeId=12454&objectID=c00805471
5 beeps = Pre-video memory error which means that the northbridge on the motherboard is faulty. You need a new mobo, this one is dead.
HP Compaq dc7700... | Answered on Feb 03, 2019
5 beeps for an AMI BIOS, which I think you have, means you have a processor error, or, in other words, the CPU.
Just to be sure, disconnect everything BUT the video, CPU, and memory. See if the result is the same.
HP Compaq dc7700... | Answered on Nov 27, 2015
if the keyboard doesnt work than you have a problem if its a USB keyboard the pc should automatically detect it and install it... just give it a little bit of time to look for the drivers and install it
HP Compaq dc7700... | Answered on Sep 22, 2014
The green light comes on where? On the laptop?
HP Compaq dc7700... | Answered on Jan 13, 2014
Open command prompt and type chkdsk /r and press Enter. It will ask for Y/N then press Y and restart the system.
do this if same issue coming again then comment on this.
HP Compaq dc7700... | Answered on Oct 11, 2013
the microcode needs to be updated using a bootable flash drive. you can get the file from the hp website
software best guess-
-you have gotten a virus that is affecting your system files.
-your system files have been damaged.
do a good scan with some virus protection and remove the viruses
- if it shows viruses affecting system files-and that virus cannot be removed by any regular virus protection.
try watching a few combo fix tutorials-last resort for a malicious unmovable virus.
hardware best guess-
sounds like an overheating issue try buying a good case fan.
if that does not work try removing your heat sink from your processor wiping both clean of paste or residue and re applying thermal paste. my favorite type is arctic silver
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tyler_d7f5052aae55714c
HP Compaq dc7700... | Answered on Aug 18, 2013
how many hard drives do you have two or more when reset bios default it can happen.you must be sure to start from the drive there windows is.bios optimal default probely changed drives
HP Compaq dc7700... | Answered on Apr 01, 2013
PCI Simple Communications Controller
HP Compaq dc7700... | Answered on Feb 13, 2013
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
HP Compaq dc7700... | Answered on Jan 05, 2013
HP Compaq dc7700 PC Desktop Logo
35 questions posted
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
dc HP
  • dc HP
Most Popular Question
no signal monitor hp dc 7700
  • Computers & Internet
