I have Windows Vista operating system - but again have never had problems before. I have connected the cable to another USB port as well. One of the diagnostics I ran said that the printer was not connected. I also shut down the computer, turned off the printer, unplugged the power source to the printer and that did not help.
SOURCE: Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
SOURCE: Not Printing!!
hmmm..well..this is a fractured driver issue for certain. I have some notes on this in my Tips and Tricks section, you may find of some value.
SOURCE: Vista Shuts down with hp officejet j4580
Disable all the startup items and your security software and firewall. Then try installing the printer. If you still have the same problem try installing the printer by connecting to a different USB port. You can also uninstall all the USB port from device manager. restart the computer and then install the printer.
Thanks
SOURCE: HP laserjet 1320n keeps printing jetdirect configuration page
Are the proper drivers installed on each system?...Vista will not work properly on XP and vice versa. Make sure they are insttalled correctly
SOURCE: hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
It will not print - just says error printing.
