When I start my dryer, the status light does not start at the Sensing position, but rather goes immediately to Wet, and the clothes are not drying. The burner is operating, however, it stays on for only 8 to 10 seconds at a time, and not very often, so the clothes are not drying. The dryer should go first to the Sensing position and then on to Wet (or something else), but it is not doing this. Help!
If the heat is only staying on for a few seconds and cutting out the vent line could be clogged,pull out the dryer,remove the vent line from the back and start it,if the heat stays on the vent is blocked,this is the easiest thing to start with,if the vent is clogged you can try a leaf blower and blow the lint out of the vent line
SOURCE: Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
SOURCE: Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
SOURCE: my dyer will not dry the clothes
First unplug your dryer from the electrical outlet. Next pull your dryer out from the wall. DIsconnect your flex outlet hose from the dryer and make sure it is not stopped up with lint etc. Next check the wall adapter to make sure it is clear of lint etc going to the outside of the house. If both of these are clear look inside the dryer outlet by looking in the tube where the flex hose was connected. You will need a flashligt to do this. If there is anything stopping it up remove it. If your dryer is getting hot but not drying there is probably something keeping the air from going out of the dryer to the outdoors.
SOURCE: Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
