20 Most Recent Maytag EPICz Electric Dryer Questions & Answers
F01 code on a maytag epic z dryer
Check your fuses first. That's all mine was when I did the have heat
9/28/2018 10:48:17 PM • Maytag EPICz... • Answered on Sep 28, 2018
There is no heat...is there a heating element or fuse and where are they located
Most likely a fusible link which melts as a result of overheating.
3/15/2015 8:06:50 PM • Maytag EPICz... • Answered on Mar 15, 2015
Get to the drum in a maytag epic z dryer
You have to take off the top remove the control panel and bottom toe panel to get at the screws for the front panel disconnect the wires for the door switch
1/29/2015 11:45:06 PM • Maytag EPICz... • Answered on Jan 29, 2015
Wont cycle to dry clothes
When the dryer door is open, you should be able to find a switch (it may be just a button protruding from the cabinet). The switch turns the machine off when the door is opened. It may be damaged or worn out.
6/13/2014 1:59:26 PM • Maytag EPICz... • Answered on Jun 13, 2014
0answers
0answers
Clean lent filter
The unit is seeing a restriction in air flow disconnect the exhaust at base of machine turn to air dry or fluff you should get good air movement coming out of the exhaust I will assume the machine worked when new if flow is weak then there is lint in the blower air passage from the machine if good you will know the difference the the restriction is in the exhaust exiting the house on one occasion i did encounter a bad control if everything passes the test an dryer is operating correctly and you still have a light leave it control is not cheap for an annoying light
3/23/2014 3:54:07 PM • Maytag EPICz... • Answered on Mar 23, 2014
No heat
Check circuit breaker it will still run but not heat if part of the breaker is tripped
11/23/2013 12:16:16 PM • Maytag EPICz... • Answered on Nov 23, 2013
0answers
Wheres the thermal unit in the lint or discharge tube
Easyest way is to follow the wires from the heater element, there will be two one near the heater element and one near the vent exhuast.
1/10/2013 12:12:04 AM • Maytag EPICz... • Answered on Jan 10, 2013
Maytag Epic Z Washer F-20, Water Inlet replaced, still F-20 Error
Chris an F-20 is usually a clogged filter on duet washers. Did you go by the tech sheet in your machine? It gives the codes and remedys and is in a jacket behind the kickplate which you remove to get to the filter. You will need a quarter inch nutdriver to gain access. SERVICE MANUAL is HERE on my manual page
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
12/12/2012 6:40:30 PM • Maytag EPICz... • Answered on Dec 12, 2012
Maytag EPICz Electric Dryer Logo
70 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
clean lent filter
  • Dryers
