Apple MacBook Mac Notebook Logo
Elizabeth Smyth Posted on Apr 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Missing driver for soundcard apple xp
Volume control icon disappeared from taskbar
Anonymous
Level 2:
New Friend:
  • Expert 34 Answers
  • Posted on Apr 02, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
34
Questions
Helped
11035
Points
104
Are you sure its a missing driver or did the volume control get changed
you can get it back go to the start menu then type adjust system volume and click and drag it to your custom taskbar
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
106
Points
6
Go into settings or the taskbar settings, it should come up with the volume tool there but if it doesn't then I do not know what to do.
Speaker icon missing from task bar
Click on the Start button, then click on Control Panel from the right-hand side to delve into your computer's settings. From the Control Panel, click on Sound and Audio Devices to bring up your audio settings. Check the Place volume icon in the taskbar and then click Apply. You should now be able to see your volume icon from the taskbar again.
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
2answers
No audio
Is this the 1st time you used it?
Check if the Soundcard Driver is already installed
Right Click "My Computer or Computer" in Windows taskbar Select Properties Select Device Manager Look for your SoundCard Double Click, check if the device is working properly
If the soundcard driver is already installed, check your speaker connections & your speaker
Volume icon keeps disappearing from system tray
Volume Control - The volume icon does not appear in the notification area (system tray)
Go to Start/Control Panel/Sounds and Audio Devices.
On the Volume Tab under Device Volume, put a check in the box that reads: Place volume icon in the taskbar.(Classic View)
If that has been tried:
Place your XP CD in then go to Start/Run and type in:
EXPAND -R X:\I386\powrprof.dl_ C:\Windows\System32 (X- is your CD location)
Once done: Go to Start/Run and type in: regsvr32 stobject.dll
or
How to fix system tray icons missing in vista and xp
For those who like to do it manually, open the command prompt and type the following two commands one by one:
From the command prompt, type
"taskkill /f /im explorer.exe"
"explorer.exe"
Hope it helps.
My computer xp not come sound volme icon, what i do
Please check if the sound driver is installed, if sould is available but the sound icon is missing please follow the following steps.
Click on start
Click on settings / control pannel
Click on Sound and audio devices
In the volume tab you will find a check box Place volume control icon in the taskbar
check this box if you need to have a volume icon in the system tray / notification area.
If the above option is not working or sound driver is not installed, please download the updated driver from the website or the CD that came along with the sound card and then try the same steps above.
3helpful
The volume icon on my taskbar has been deleted from my computer how can I download it again
Missing icon from taskbar
1. If you have uninstall your Audio drivers from your system the volume icon will not show in the taskbar. You have to reinstall the audio drivers to restore the volume icon back to the taskbar
2. If the your volume icon is missing from the taskbar and you did not uninstall the audio drivers, then go to Start -> Control Panel -> Sounds,Speech, and Audio Devices -> Sounds and Audio Devices ->"Place volume icon in the taskbar" box -> Uncheck & check -> Apply & OK and your volume is restore at the taskbar. (Reboot if necessary)
Hope it helps.
My volume icon is missing how can i replace it?
I will assume youre using XP it has a tendency to disappear sometomes. Go to control panel / sounds and audio devices, you will see a checkbox to show icon in taskbar. Its probably still ticked but just untick it and retick it then apply and it should be back there. Cheers from Scott and plz vote
1helpful
2answers
How Do i iNSTALL sOUND iN MY wINDOWS xp ?
You need audio drivers, it would've helped if you had stated what soundcard you have?
1helpful
Volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
Method 1: Add the Volume icon
To add the Volume icon to the notification area of your computer, follow these steps:
1. Click Start, and then click Run.
2. Copy and paste or type the following command in the Open box, and then click OK:
mmsys.cpl
3. Click to select the Place volume icon in the taskbar check box.
4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2.
Method 2: Save a new copy of the Sndvol32.exe file on your hard disk
If the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk.
Prerequisites
This method requires you to have your Windows XP installation CD.
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
2. Click Start, and then click Run.
3. Copy and paste or type the following command in the Open box, and then click OK:
cmd
The command prompt opens.
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
5. Copy and paste or type the following, and then press ENTER:
cd i386
6. Copy and paste or type the following, and then press ENTER:
expand sndvol32.ex_ system_root\system32\sndvol32.exe
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
expand sndvol32.ex_ c:\windows\system32\sndvol32.exe
Note There is a space between "ex_" and "c:\windows" in this command.
7. Type exit to exit the command prompt, and then press ENTER.
8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
Hopefully the Volume icon is now displayed in the notification area.
3helpful
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
