I hvea vhs cassette, and inserted it to watch, I reminded it, suddenly it stopped, when I tried to watch, it had audio but no picture.
Hi,because you have audio the problem is on the video head of your VCR If you have a VHS cleaner run it on the player and until you can have a picture If still video is missing clean the video head manually open the top cover then you can see a stainless round drum this is the video head get a a small piece of bond paper moistened it with an alcohol the wipe it on the side surface of the drum where you can see the heads repeat the procedure until you obtain picture (make sure you turn power off or unplug before cleaning it manually)
SOURCE: VHS has audio but no video
we cannot get the vcr portion to work only the dvd player works what are we doing wrong?
Have the same problem? Click Here
Best Solution
posted on Oct 24, 2007
MikeNJ1964
Rank: Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video
(yellow) RCA jack and S-VIDEO jack. If you are using the Component
jacks, the DVD side will work but the VCR will not. This is because
the quality of video recorded on VHS tapes is so much lower than
component quality video.
Thank you for rating this solution.
SOURCE: Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
HOOK THEM UP SEPARTLY,,,DVD COMBO WITH RCA JACKS
SOURCE: Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
My vcr when played vhs just have audio no picture.
Yes I cleaned the heads and it works ok, thank you.
