Electronics do not work (preamp is not amplifying sound).
The process if covered right here:
http://www.takamineguitars.eu/uk/support/preamp-removal-and-installation/
IMHO- the guitar manufacturers are the top of the line when it comes to customer service and online support data.
THE LINK IS BROKEN. try this video: https://www.youtube.com/watch?v=qDoR_9j18PY
SOURCE: Hi i recently bought a
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
SOURCE: I had bought a parker fly mojo bass, but lacks the
The first thing is to check the battery. The battery is draining anytime you have a cable plugged into the guitar. Use ONLY alkaline batteries. The rechargeables only deliver a lesser voltage.
Check that no wiring is shorting to the paint inside the electronics cavity... the paint is conductive.
SOURCE: Hi! My TP-4T preamp works
Hey hi!! i am sorry but i am posting this becausing i am having the same issue with my takamine EG 260C TP-4T Preamp. It only works when the tuner is one. Please let me know too if you happened to find a solution for this issue.
help me please
the link is broken
