How can I improve the suction on my Kirby g upright
SOURCE: No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
SOURCE: Kirby G4 without suction
change your belt, if there is suction from the hose, and you cant see any blockages in the area where the brush roll is then you need to change the belt, even if it isnt broken. putting your hand over the nozzle to feel the suction is not the way to tell if it has suction.
SOURCE: Kirby Ultimate G Series Diamond Edition
Take a look at the help article here. If bristles are worn you may need to install the brush roll in a different position (details HERE) or purchase a new brush roll.
Good Luck
Rocky
