SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions [email protected]
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
SOURCE: Kenmore 1914 Zig Zag needle wont move side to side
I have this machine and love it too. I am glad to see I was passed down a great machine from a great person. I do not have the arm cover to the machine or any cams, extra feet or Manuel. I have made do for many years but would like to know where to get parts.
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
