Konica Minolta bizhub C351 All-In-One Laser Printer Logo
Anonymous Posted on Mar 01, 2012
What does center erase mean on Konica Minolta Bizhb C351 mean?
Anonymous
Level 2:
Sniper:
  • Expert 62 Answers
  • Posted on Mar 08, 2012
Anonymous
Expert
Level 2:
Sniper:
Answers
62
Questions
0
Helped
83146
Points
160
Hi Meggleton313,
If you needed to photocopy a couple of pages (side by side) from say a magazine or book. You would lay the magazine on the glass, opened on the 2 pages you want. You could use center erase to remove the area where the spine of the magazine would be. Thus avoiding the dark and blurred image traditionally associated with copying this kind of media.
Kind regards
m-press.biz
5 Related Answers
Anonymous
  • 167 Answers
  • Posted on Sep 10, 2008
SOURCE: LOADING STAPLES
http://help.bt.konicaminolta.ca
go here to get that Manual, it is good to have anyway
toddmat
  • 44 Answers
  • Posted on Nov 17, 2008
SOURCE: Help Konica Minolta c351 mac user
One is that the fold and staple option only works on 8.5 x 11 sized paper, thus printing onto a 11x17 spread and then folding. If letter paper is not selected, that will grey it out.
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
Anonymous
  • 158 Answers
  • Posted on Nov 17, 2009
SOURCE: Malfunction Detected C-0206 on Konica Minolta C351
this error code means that tray 3 paper could not lift up to the feed rollers. open the tray and check the paper tray and checkthat the paper is loaded correctly pull all the paper out of the tray and check to see if any is folded or crumpled if the paper is ok it could be the lift motor has failed or the main boardPF or main boardMC or the dc power supply needs to be replaced.
to reset the code leave the machine on and open then close the front door
Anonymous
  • 44 Answers
  • Posted on Nov 29, 2009
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
2answers
1helpful
2answers
My konica minolta bizhub 361 has an error code c-2801.... what does that mean?
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
I have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
Konica Minolta C351: stop Banner Mode?
this problem can be remove by upgrading its firmware. ask your technician to upgrade the firmware of the machine.dont replace the board. try this.
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
2helpful
2answers
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
