Drills Logo
Posted on Feb 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Smoke from Motor - Drills
  • Anonymous Feb 16, 2012
    Expand on this and I'll help.
Anonymous
Level 3:
Genius:
  • Master 1,212 Answers
  • Posted on Feb 18, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1212
Questions
0
Helped
469702
Points
2874
If oil got on the brushes, this can happen, and it will clear. It can also happen when windings have shorted out from being run too hot with subsequent failure of varnish. The brushes will tend to arc and the commutator contact bars begin to erode and melt. The motor may continue to run albeit slowly and without power.
Also too, sometimes the speed control circuit flames out and appears as smoke from the motor. in which case the motor becomes nonfunctional.
The same can happen when wires get shorted out.
Hi , I have a 2005 Toyota Hilux 3.0 D4D when I startup the motor there is no smoke when I excelerate still nothing but as soon as I get to 3000rpm the motor starts to rev up and down and blue smoke co
I have a 2012 dodge ram 1500, I am wanting to raise it 2 inches with a leveling kit, I will need to readjust the fog lams and headlights, I know how to do the headlamps but need to know how to do the fogs lamps?
Thanks
1helpful
White smoke from exhaust from 06 hummer 3.5 no engine light on and run perfect, just the smoke that i do no like.
Sounds like a blow or cracked head gasket, the white smoke is either water or coolant being burned in the motor. With this type motor, I would get it checked ASAP before any more damage is done to the motor.
K my 460 runs like **** its missing and number one plug was black...i changed wires- plugs -and cap and now runs worse and blowing white and blue smoke....whats wrong with it?
give me more info about your plug, is it black by oil or black powder from gas ?
in the other hand, smoke white is a motor cold on winter, smoke blue is oil inside motor, smoke black is gas not burned,
so be shure exactly what color is...
My engine is jumping smells like smoke fluids are
sounds like a motor mount is bad. does the motor kick back hard when putting in drive or reverse? if so you need to change the bad motor mount.
2000 Nissan Quest Smoke and Miss
The Motor is Burning oil. This is the cause of the White Smoke. The noise is Possibly a Lifter inside the Motor. The only way to get these to stop is to Rebuild that Motor at this Point.
Burning smell and smoke from motor
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
Smoke
This is caused when oil gets passed the rings n the pistons. Its due to wear and tear or old motor needs rebuilt. now you can put a bottle of motor honey in it. or some of that smoke be gone you find in wal-mart auto section of store this will greatly reduce your white smoke till you can get it rebuilt .
1helpful
SMOKE
it may just be a wire rubbing the tub and the insulation is gone. smoke means something is not right. the drive motor will smoke if the windings overheat neccesitating a new motor. - the start or run capacitor for the motor may be bad.
Smoke from washing machine
CHANCES ARE ITS THE MOTOR START MACHINE RUN IT IF POSSIBLE FOR A FEW MINUTES TILT MACHINE BACK AND FEEL THE MOTOR IF IT IS HOT YOU NEED TO REPLACE IT (THE MOTOR)
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
