20 Most Recent Black & Decker RD1440K 85th Anniversary 14.4V Cordless Drill/Driver Kit Questions & Answers
Open the chuck as wide as it will open and look inside to see what type of screw/bolt it uses then using the correct tool insert it into the chuck and undo the bolt/screw, usually it will have a left hand thread so to unscrew it needs to be rotated in a clockwise directions, hold the chuck tightly but dont use excessive force if this does not work then try unscrewing it in the opposite direction, at all times be firm but like I mentioned earlier dont use excessive force.
Black & Decker... | Answered Yesterday
Good day
Can you please supply more information
Thank you
Black & Decker... | Answered on May 29, 2019
Request the wiring diagram directly from Black & Decker.
Black & Decker... | Answered on May 12, 2019
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Black & Decker... | Answered on Jan 30, 2019
there's a button behind the trigger for locking the trigger at full speed. there's a button above the trigger for clockwise and counter-clockwise rotation. there's a button on the top for hammer mode or regular mode. Hammer mode is for concrete, it basically makes the drill bit hammer in turning the concrete underneath it to dust as opposed to cutting with a sharp edged drill bit for regular stuff like wood or metal. If yours has numbers those are for torque settings, and are hardly ever used by professionals.
Black & Decker... | Answered on Oct 14, 2018
Hello, Mukund -
I am answering from the USA.
There is a Stanley Black & Decker (the current name of the Black & Decker Company) business in Dubai. See the location information here:
http://placesmap.net/AE/Stanley-Black-Decker-197888/
You can contact them by phone and ask about a battery for your screwdriver.
Best wishes.
Black & Decker... | Answered on Jul 02, 2018
Had this question before, try this site Myblackanddecker.com and see if that helps, if not let me know and I will dig deeper into their files for you.
Black & Decker... | Answered on Jun 07, 2018
Keep turning it off and on several times at the socket sounds like you need to trick the memory
Good luck
Black & Decker... | Answered on Dec 17, 2017
Turn the drill over and push the switch all the way in.
Black & Decker... | Answered on Oct 31, 2017
Close the chuck onto an Alan Key and use it to twist the drill off.
If it has colors, red is usually the +
Black & Decker... | Answered on Aug 12, 2017
I think you need to contact Black and Decker directly,,,, I do not think they monitor this site..
Black & Decker... | Answered on Jun 26, 2017
Black & Decker RD1440K 85th Anniversary 14.4V Cordless Drill/Driver Kit Logo
0 questions posted
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Thomas F. Schneider
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Drills
Most Popular Question
remove dr200 black decker 3 8 drill
  • Drills
