20 Most Recent Diamond Products 01738 Core Bore Weka DK12 Drill Motor Questions & Answers
You might be able to make your own by picking up 2 lithium ion batteries at home depot. I only saw the Hampton bay solar cells there.
Drills | Answered Yesterday
Yes. As long as they are both the same format. The only difference is the capacity of the battery. The 2.5 Ah will last longer than the 2 Ah will on a charge. The charger will work for both.
Drills | Answered on Oct 01, 2019
Short answer, yes. Longer answer, maybe maybe not. IF the Lithium Ion battery is fully charged when you install it, the bike should be able to keep it fully charged. Lithium Ion batteries do not tend to lose their charge rapidly just sitting there with nothing on. It takes a special charger to charge them to begin with. Colder days, you need to "wake up" the batter with a couple hits of the starter or turning the headlight on, automatic with the key on most bikes. They simply won't give full power until you "wake them up". I am assuming you are talking about a replacement motorcycle battery, not some random lithium battery in this case. One problem is the lithium is much more expensive than the lead acid battery, and if you let the voltage fall to even relatively high levels (sometimes as much as 11 volts) it can ruin the battery totally. Lead acid can be much more forgiving. Leave your key on with a lithium, you could kill it beyond recharging. Lead acid batteries this is not the case, and lead acid batteries can be refreshed with fresh acid, once a lithium is gone, it's gone, there's no saving it. I would rethink why you want a lithium battery. It does save weight and often size, but I see no real advantages over the standard battery in use.
SEARCH GOOGLE
Drills | Answered on Sep 29, 2019
Fixya does not sell batteries.
Drills | Answered on Sep 17, 2019
Diamond Products 01738 Core Bore Weka DK12 Drill Motor Logo
Popular Tags
7 questions posted
Top Diamond Products Drills Experts
Marvin
Marvin
john h
Are you a Diamond Products Drill Expert? Answer questions, earn points and help others
View Most Popular
  • Diamond Products Drills
Most Popular Question
know lithium ion nicad batteries tools
  • Drills
