A
Anonymous Posted on Feb 13, 2012
C-2702 error on konica minolta printer - Konica Minolta Office Equipment & Supplies
Antonio Fernando
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 22, 2019
Antonio Fernando
Contributor
Level 1:
Answers
Questions
0
Helped
2385
Points
6
Hie, can i help me code c2702 in bizhub 250
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 12, 2017
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914013
Points
11960
Model number would help #####################
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Anonymous
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Sep 03, 2009
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: have a error flashing. Have disconected and
pull its drum cartridge out then fix it again.now restart the printer and check.
Error code 2702
check magenta Charge grid.
2answers
Code irror 2702
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Rror 2703
Subject:
C-2702 and/or C-2703 code.
Description:
Solution:
PROBABLE CAUSES:
1. Failed T/S corona.
Remove the T/S corona unit. If blank copies can be printed without a service code appearing, replace the T/S corona unit (p/n 57AA R715 00).
2. The HV unit has failed.
Replace the HV unit (p/n 56AA 8401 2).
22helpful
5answers
Konica minolta pagepro 1500w toner low error
recharge toner powder. 'BROTHER' toner powder is suitable for it.rate 100 Rs. only.
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Bizhub 420 error code c-2702
When you open the door on the right side on the door is a assemble that has paper guides cover to very find wires, that assemble is either bad or the wires in the assemble are bad, have a tech look at it might require replacement.
3helpful
Hi i have code c-2702 in konica minolta 600
Sir,
This code should clear by turning off then on the machine. If that does not work then you will have to check the High Voltage Charge Corona. Has the drum unit been recently pulled out? If so check the Charge Corna housing is it properly installed.
I have a malfunction detected c-2702, thats all it says and it does not print nor do anything
Hi timothy j352,
I would generally advise you to get new installation software, however, Konica/Minolta doesn't offer driver updates through downloads!? So, I would suggest this: right click my computer icon on the desktop(if thats where yours is) properties. Click Hardware tab, device manager, imaging devices, your printer, right click, choose uninstall, don't uncable anything, reboot, windows will recognize new hardware and try to install. I hope this helped a little, its unfortunate that Konica/Minolta has left its customers with no update recourse.
Thanks for using FixYa.com
Sincerly, cyyyd7
3helpful
4answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
