20 Most Recent Konica Minolta Bizhub Press C6000 Copier Questions & Answers
What is the error code C-XXXX or SC-XXXX or Jxx-xx what was it doing when it happened?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Feb 06, 2019
the whole section that houses the toner is not closed properly
Konica Minolta... | Answered on Mar 25, 2018
Check you your yellow developer unit, last time the developer was changed, or bad sensor on the under body of the yellow developer unit, worse case bad main board$$$$$$$$$$$$$$$$$
Konica Minolta... | Answered on Mar 11, 2018
Well possible two items the code is for the paper feed motor either you have problem with a paper issue or more likely the WASTE TONER issue since the Paper Feed Motor (M-41) handles to jobs running the paper feed system and waste toner system might harden old toner in a tube section preventing the motor from turning get a tech out to check the entire waste toner system and or paper feed issue
Konica Minolta... | Answered on Feb 25, 2018
Main body: Writing correction drive abnormality
Cause> The tilt correction home sensor /M (PS71) turns OFF while the tilt correction motor /M (M75) in the writing unit is ON.
Estimated abnormal parts> • Printer control board (PRCB) • Writing unit
Konica Minolta... | Answered on Feb 05, 2018
If you are talking about the IC-601 it is mounted on the back of the copier
Konica Minolta... | Answered on Jul 27, 2017
check magenta Charge grid.
Konica Minolta... | Answered on Mar 12, 2017
check the yellow toner and deveopler and yellow drum
Konica Minolta... | Answered on Mar 11, 2017
service mode then clear the counters, should have done it before installing the drums.
Konica Minolta... | Answered on Jan 08, 2017
sensor might be stuck or there might be a small piece of media stuck or the sensor is bad, or the acturator can not go back to its proper position
Konica Minolta... | Answered on Jul 10, 2016
reinstall the toner bottle correctly
Konica Minolta... | Answered on Jul 09, 2016
install OEM toner not third party
Fusing error have tech look at and reset
Konica Minolta... | Answered on Jun 26, 2016
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Konica Minolta... | Answered on Jun 17, 2016
Scanner image
processing board
(SCIPB)
• Memory control board /1
(MCB1)
• Overall control board
(OACB)
(PRCB)
any one of the above boards$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ have tech come reflash the firmware first
Konica Minolta... | Answered on May 14, 2016
what do you mean cross check??? like you switch the entire fuser with another one, then might be the main board.
Konica Minolta... | Answered on Jan 18, 2016
check the yellow developer might require developer replacement and or the sensor last PM??????????????????
Konica Minolta... | Answered on Jan 13, 2016
Have you had the developers and drums replaced or does the screen say Replace PC Drums? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the developing units next to the drums. Did you recently replace the drums and the developer if so did you clear the counters for the drums and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developers and a new drums and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the drums unit replace the developer. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. .
Konica Minolta... | Answered on Jan 10, 2016
Konica Minolta Bizhub Press C6000 Copier Logo
Popular Tags
53 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
please set replenish toner unit
  • Office Equipment & Supplies
