It all freezes in the fridge compartment for no reason
SOURCE: My Whirlpool refrigerator leaks water
The problem with my fridge is not resolved!!!!!!! I'm very disappointed!!
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
SOURCE: my daughter's mini fridge has a freezer
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Testimonial: "We're gonna try the steps you suggested right now. I figured it was something along those lines, but I wasn't entirely sure. Thanks for the help!!"
SOURCE: why does everything in my fridge freeze eventhough
Looking over your refrigerators service manual and wiring diagram shows and electric damper that controls the flow of cold air from the freezer to the fresh food compartment. I just may be stuck with a little frost or we need to check it along with your jazz electronic control board part number 12868513. That board appears to control temperature, defrost and most everything on your model. And if not stuck the electric motor could be bad on the damper. These model are a little tricky so hopefully we can find the problem soon. If you would like to approach this yourself I would first unplug for a little time and try to force some warm air into the damper with a hair dryer to see if the damper will begin to move. Turning freezer colder also may cause the damper to shut more so as to keep the cold air in freezer. If the controls are not responsive then it's a toss up between the two. Be back with photos and links, Thanks Sea Breeze
