LTD Watch Bowflex Strapless Heart Rate Monitor watch Logo
Posted on Feb 07, 2012
How to use calorie counter on bowflex classic strapless heart rate monitor watch
How do i get the calorie counter to work while I am exercising?
4helpful
I own a bowflex precisionxt heart rate monitor and I cannot find the manual. Where can I obtain one?
Try this:
search-manual-online.com/bowflex-precision-xt-heart-rate...
Aug 29, 2011 • Watches
MIO MOTIVA STRAPLESS - My problem is that the watch is brand new out of the box, but the actual top right button (Start/Stop/-) doesn't work. Also the actaual sensors don't seem to be picking up my pulse...
Unfortunately MIO do not have repair services in Australia, probably would have to send it back to the US. Hopefully you can work with the seller to fix the issue. I know when you buy through mioglobal.com their customer service is excellent.
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
How do I reset the chronograph? Once I start it I can't find a way to reset it.
In heart rate mode, click reset to go to Calorie burned mode. In that mode press and HOLD reset button and this should reset all lap,calorie data. etc
1helpful
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
3helpful
I have a mio watch,installed new battery.hear rate monitor does not work,much too high
Have you contacted their customer service team? They are great at resolving issues and really stand behind their product. Their Facebook page MIOWatch also has lots of troubleshooting and FAQs too.
OK.heart rate doesn't work right and the calorie burn is off too. Also, how can I set it for my body type so it can read the right calorie burn....the manual doesn't say. NOT HAPPY with this poduct!
Thank you for contacting FixYa.
This is a rather complex watch and the best person to contact on this one is going to be Timex themselves. Sorry.
You can contact them at this link:
http://www.timex.ca/en/contact.aspx
Best regards.
Jewel
Do I have to wear my transmitter to review calories burned?
Without knowing how hard you have exercised (heart rate) it wont be able to calculate how many calories you have burned.
Andy
I have the timex fitness trainer and it is calculating my calories for a man and I need it calculated for a woman. Help!
Simple! men and women burn calories at the same rate. And the more muscle you have the more calories you will burn to conduct an excersize. And the more fat you have, the more calories you will burn from fat.
Top LTD Watch Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LTD Watch Watch Expert? Answer questions, earn points and help others
