20 Most Recent Polar F6 Wrist Watch Questions & Answers
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Polar F6 Wrist... | Answered on Dec 17, 2016
I suggest you have to check your battery first. It may be underpowered. Replace it with the new one and then check light again.
Polar F6 Wrist... | Answered on May 10, 2016
No, you can buy replacement battery from amazon: Energizer CR1632 3 Volt Lithium Coin Battery pack of 5 and change it by yourself for free :). cheers
Polar F6 Wrist... | Answered on Nov 29, 2014
I had the same problem and attempted what banjodoug suggested above. It did not help. I had a faint display even before I re-inserted it into my watch frame. I surmised it wasn't the battery position.
I then took apart the damn thing and put it back together several times, each time rushing to push the setting/center button only to derive the same problem over and over.
I then took it apart one more time and pinched in all of the sides of the metal frame that holds it all together, thinking that I had a bad ground. After I did that, I reassembed it and waited. The display came on with the test display and then eventually went to the standard display on its own and all was good to go.
I suspect the issue was solved by correcting an improper ground and a proper initialization process - both solved by the steps I took above.
Hope it works for you!
Polar F6 Wrist... | Answered on Nov 20, 2013
The buttons on the right (in the pic) or while facing you are the way into the menu's.
#1 - Push the center right button (exercise will appear)
#2 - Push the upper right button (settings will appear) use the upper right or lower right buttons to scroll if neccessary
#3 - Push the center button (a menu will appear)
#4 - choose Watch, use the upper right or lower right buttons to scroll if neccessary
#5 - Push the center button to choose watch, once highlighted
#6 - use the upper right or lower right buttons to scroll through the watch menu
#7 - Choose Time
#8 - Continue to use center button and scroll buttons to choose and set.
Important button to know - the bottom left button is a reverse button. Make a mistake, just tap that button, keep tapping to go all the way back to the main menu.
Polar F6 Wrist... | Answered on Dec 31, 2012
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Polar F6 Wrist... | Answered on Dec 09, 2012
I had the same problem, the screen would be sharp when adjusting setttings after battery-replacemnet only to fade as soon as seconds after startup.
In my case the solution was to dissasemble the watch, use a toothpick or whatever to remove dirt from the copperplate lines (three long lines and one short line) that connect the hardware-part of the watch to the screen (the backside of the screen has lines that correspond to that of the copperplate lines on the frontside of the hardware-part).
Hope this helps, it worked out great for me!
Polar F6 Wrist... | Answered on Jun 16, 2012
Polar F6 Wrist Watch Logo
144 questions posted
Top Polar Watches Experts
Tom Chichester
Bill Boyd
Mr.Mike
Are you a Polar Watch Expert? Answer questions, earn points and help others
View Most Popular
Polar Watches
  • Polar Watches
Most Popular Question
polar f6 battery replacement
  • Watches
