20 Most Recent
Polar F4 Heart Rate Monitor Watch Questions & Answers
I cannot set my Polar
Hello Paso,
Lengthy setting: It can take a while to change time or adjust weight as
the number can be adjusted only upwards in one direction. If you
overshoot, you have to keep pressing until the number reaches the top of
the range. The number will then loop around and start from zero again.
Under the settings, limits, the
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
The display is frozen and
If there are no reactions to any buttons, reset the
wrist unit by pressing all the buttons
simultaneously for two seconds. All other settings
except time and date will be saved.
manual is here
