Hello, we started to get an error message every time we are trying to take a picture with our Panasonic model no DMC- TZ 15 camera -" please turn camera off and on again"- which make impossible to take a pic.This is hapenning only when we are using REC menu, when we are operating in the other menu it behaves .Does anyone had similar problem? how to get it fixed? thank you
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
SOURCE: Continuous or fast photo captures
Pics are about 2 per second. If action is fast, like downhill snowboarding, then may not be fast enough for you. Use MOVie mode at 640 by 480. Not bad.
SOURCE: Panasonic DMC-TZ3 2GB Memory card says full with very few pics.
It may also be that the card isn't being read properly and you are using the onboard memory which is about 15 photos worth.
SOURCE: please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
SOURCE: Problem with Panasonic DMC-TZ5, can not take pictures with Flash.
My TZ5 has developed exactly the same problem. I took it to DK Audio Services at Horley,Surrey,RH8 9GA. who repair cameras for Panasonic and was told by the receptionist that although the camera works with the flash off at present it will eventually pack up altogether. She suggested that when I get the quote I phone Panasonic on 08705 3577 357 to try and get them to pay for the repair, it seems it is a known problem! My camera is just over a year old!!
Testimonial: "Thanks, for your comment. Its good to know I´m not the only having this problem with the camera."
