Console comes on and acts like the tradmill is running, but the belt doesnt move. I removed the motor cover and the motor is clean, the control board is clean, the red LED light is on, not flashing, and everything is plugged in.
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
SOURCE: Nordic Track c2200 no speed
It likely is the controller if it was speeding up and down erratically. Check the position of the reed switch to make sure it is positioned about 1/8" away from the magnet in the side of the front roller pulley. Run a diagnostic program as follows. Press the stop and speed arrow up buttons until you insert the key. Press the stop once or twice until you get to a screen with 2 sets of zeros. Now press and hold the speed arrow up button until one number set shows 8.5. The unit will go to full speed so be careful not to be on the walking belt. The other number set should top out shortly at either 10.0 or 12.0 based on whether your speed buttons go up to 10 or 12. If the motor races past your top number,( don't let it run that way as you may damage the motor), pull the key. If the readout is above or below your target by more than .4 and not flucuating a lot, you may need to tune the potentiometer on the controller. Counter clockwise turn with a phillips screwdriver turns the motor speed down. Be carefull not to short out the controller board by touching components with screwdriver. If not comfortable ask a friend with electronics background. If you turn the pot. too far it will break. It will not go a full revolution in either direction and tiny movements are recommended. Again I believe your controller needs replacing.
SOURCE: BUYER BEWARE!! I purchased
Watch this video: o 1 Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord. o 2 Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place. o 3 Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled. o 1 Unplug the treadmill and remove the safety key. o 2 Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S. o 3 Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models. o 4 Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw. o 5 Reverse the directions to put the hood back on and the treadmill upright in the original position.
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
2. Reed Switch
Check too:Optical Sensor. If have it
My treadmill is a nordic track NTL09707.4
There may still be a problem with the LCB.
