Forgot the admin password need to factory reset it.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
SOURCE: forgot admin password for D-Link DIR-628
There is a "reset" button on teh back of the router. Use a paperclip, pencil, pen, etc. to depress the reset button for about a count of ten (this should reboot the router) then release. Your router will be reset to factory standards, including a blank password. Any changes you had previously made to your settings will be lost.
SOURCE: D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
