20 Most Recent
D-Link (DIR-130) Router Questions & Answers
Can i reset the password on my D-Link DIR 300 Router?
Yes, you can reset the password on your D-Link DIR-300 router. To do this, follow these general steps: Access Router Settings: Connect your computer to the router either via a wired or wireless connection. Launch a web browser and input the IP address of the router (frequently 192.168.0.1 or 192.168.1.1) into the browser's address bar. Login: Enter the router's username and password. The default credentials are often admin/admin. Navigate to Password Settings: Look for the "Setup," "Wireless," or "Security" tab in the router settings. Find the section related to changing or resetting the password. Reset Password: Follow the on-screen instructions to reset the password. You may be asked to enter the old password before creating a new one. Save Changes: Save the changes and reboot the router if required. Please note that the exact steps may vary slightly based on the router model and firmware version. If you Need More Router Support visit: Geek Squad Assists.
I FORGOT THE PASSWORD
Use the hardware reset button. Using this button will reset it to manufacture's default settings. Setting username: admin password: blank
I just want to change
To change you password, launch your configuration screen (by typing in 192.168.0.1 in the address bar of your Internet browser), Login using default username and password as above, and then click on "Run Wizard." You will have an option to Set your new password, Set your time zone, and to Set Internet connection. Follow the screen prompts, and restart your DLINK router/modem when done.
If you are having trouble resetting your password, double check your product documentation to find out how your product has been preconfigured prior to shipping. If you still cannot log in, double-check your password (if any), and make sure that your CAPSLOCK key is off. If all else fails, use that little "reset" button at the back of your D-Link router/modem and hold it down for 10 to 30 seconds (depends on your unit) to restore your networking hardware to factory default settings; and start over.
Hope this helps.
Thanks for choosing Fixya,
RJ
I forgot my password and
In order to get your router back to the original settings, you must push
in the reset button (usually on the back of the router) for somewhere
between 10 and 30 seconds depending on the router. You may need a pin or
something small to push in the button, because it can be recessed. Once
you have reset the router, the username and password will be changed to
the defaults, admin and password, respectively. One thing you must
remember is that resetting the router will change all of the router
settings back to the factory settings. This means you will lose all of
the changes you made since you got the router. Make sure to write down
any things you've changed, so you can change them back after the reset.
Also, I recommend updating to the latest firmware after the reset.
If you need more help post back!
Thumbs and testimonial are welcome!
There a great article at
General Router Setup.
I forgot my old password
Ob these stuff there should be a reset button on the back, or the bottom. The type that you simply can't see, and to push it, you need a pen, pencil, whatever.
If you got the reset button, then it takes every preferences back to default.The default password on D-Link routers is "admin" (without ""s).
Diconnect internet connnection every 2-5 min
try using different PC or laptop or move to different location dependign on the streght of the signal and also make sure that dlink is properly connected. or unstall anr re-instal your Dlink if it does not work your dlink may be defective.
Forgot password to access
You can reset yout router provided that u have ur ISP/Internet account password known.
To reset dlink router,
1. Switch ON the router
2. you will see small reset switch in back.
3. Press and hold the reset switch for 30sec while the router is powered on.
4. Then leave reset switch, unplug powercable.
5. Then after 10secs, Switch ON the router.
6. Its done. goto router homepage as usual.. then proceed to setup internet settings.
VOTE for me.,
D-link dir-130 was in the process of saving
Reset the router.
Push something small in the reset hole on the back, some routers need to be switched off, then push the reset and keep it pushed for about 20 seconds after you have switched it back on
Forgot the password so plz help me
You can reset the D-Link router to the factory default by :-
Powering up the router and pressing the reset button at the back of the router nest to the power socket.
open your browser and in the URL address box type in :-
http://192.168.0.1
The default login is admin and the password is left blank.
Networking
you need a router to make that possible using wired or wireless connection.i hope this helps
VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Installed a d-link dir-100
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
