The upper oven in my double wall oven (see above model number) started to preheat, then began beeping and displaying an F5 Fault Code. To stop the beeping, I have to turn the oven off. The lower oven seems to be working fine. Is this something I can fix myself and, if so, could I please get some instructions? Thanks.
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
An update on the problem above. I replaced the clock part as indicated by the F5 fault code. Oven is STILL not working and is displaying an F3 fault code. Since the first part cost nearly $200, do I want to continue with this process or just scrap the stupid oven? (Jenn-Air is ****.)
