20 Most Recent Jenn-Air JJW9830D Electric Double Oven Questions & Answers
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy! However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage. The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps. What type of thermometer are you using to check your oven temperatures with? If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray. You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings. It's the only way to be as close as possible with a digital probe. If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel. To adjust the oven temperature: 1 - Press Setup pad. 2 - Select the down arrow to scroll to the next screen. 3 - Select Temp Adjust using the Quickset pads. 4 - Select upper or lower oven (select models). -"Set temperature offset using the Upper Set Knob" is displayed. 5 - Enter the desired temperature change using the Set knob. The temperature can be increased or decreased up to 35 degrees. The temp. change is displayed at the top of the window. 6 - Press the Set knob to accept the change. Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
10/24/2014 2:23:47 AM • Jenn-Air... • Answered on Oct 24, 2014
I need to get a specification sheet on a Jenn-Air
I need to purchase light bulbs for Jenn-Air Electric Double Wall Oven model # JJW9830D
11/16/2010 8:21:36 PM • Jenn-Air... • Answered on Nov 16, 2010
I have a Jenn Air
This is a control board / unit problem with these models. It is not an easy repair really, but if you are extremely handy it can be done. Let me know if you want to try the repair yourself and I can find the part.
Thanks
Tim
10/9/2010 7:07:16 PM • Jenn-Air... • Answered on Oct 09, 2010
Double oven keeps tripping circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
10/3/2010 2:38:08 AM • Jenn-Air... • Answered on Oct 03, 2010
2answers
The lower oven door will not close tightly so the
You will need to adjust the door hinges so it pulls the door in tight enough.
2/28/2010 7:37:11 PM • Jenn-Air... • Answered on Feb 28, 2010
My jenn air dual oven timer, temp lights are going out
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
8/12/2009 4:37:30 PM • Jenn-Air... • Answered on Aug 12, 2009
My Jenn Air convection oven has a buzzing sound and only can get to 310 degrees.
Question edited for clarity, 'conversion' to 'convection'. Question moved to maker category. Full 'make MODEL (what is is)' in all questions please, first 3 words please. That buzzing normally happens before the element fails. It is starting to arc inside the metal covering. Eventually they pop and you get a hole in the side of the element. It isn't getting to full temperature because there is internal resistance and only a portion of the element is heating up. ..
4/7/2024 7:03:40 PM • Jenn-Air Ovens • Answered on Apr 07, 2024
Jenn Air gas wall oven turned off while baking and won't stop beeping about every half hour. If I try to reset bake degree, the bake light goes on, then off and it beeps again. Model # jgw8130ddb
Oven keeps beeping: As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power. If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control. The oven control can be accessed and replaced from the rear of the control panel. NOTE:Disconnect the power cord from the power source before removing the panel from behind the console. If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe. if Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat. You can reset the thermostat by pushing in the reset button on top of the thermostat. Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise. Read more :
7/24/2023 12:09:02 AM • Jenn-Air Ovens • Answered on Jul 24, 2023
I have a Jenn Air stove/oven. Stovetop (electric) works but oven won't. Display panel won't light up. only beeps when I push a button. Could this just need a new display board?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: 1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary. 2.Power cord plugged in?Grab the plug and wiggle to determine a good connection. 3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires. 4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. 5. 6.Even a bad relay door switch will hinder your oven from operating. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse. THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage. If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advice bcuz God is so good! Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. 1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful. 2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires. 3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective. 4.Repeat the step above for the terminals "L2" and "H2". 5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced. 6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance. 7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed. If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
7/23/2023 11:47:21 PM • Jenn-Air Ovens • Answered on Jul 23, 2023
Can this oven come back to life? its been in storage for a year. when recently plugged in, clock lit, but bake , and other roasting commands wont. Did it disprogram itself?
most older ovens will not operate properly unless the time has been set correctly to present time. Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: 1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary. 2.Power cord plugged in?Grab the plug and wiggle to determine a good connection. 3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires. 4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. 5. 6.Even a bad relay door switch will hinder your oven from operating. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
7/23/2023 11:40:08 PM • Jenn-Air Ovens • Answered on Jul 23, 2023
Every time I use th oven, why does it beep for a day or two going from one settin to another?
Oven keeps beeping: As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power. If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control. The oven control can be accessed and replaced from the rear of the control panel. NOTE:Disconnect the power cord from the power source before removing the panel from behind the console. If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe. if Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat. You can reset the thermostat by pushing in the reset button on top of the thermostat. Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise. Read more : http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
7/23/2023 11:38:05 PM • Jenn-Air Ovens • Answered on Jul 23, 2023
2answers
Jenn-air WW2780 Double convection wall oven, lower oven will not come on. Is this a touch pad issue?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: 1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary. 2.Power cord plugged in?Grab the plug and wiggle to determine a good connection. 3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires. 4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. 5. 6.Even a bad relay door switch will hinder your oven from operating. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse. THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage. If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advice bcuz God is so good! Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. 1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful. 2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires. 3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective. 4.Repeat the step above for the terminals "L2" and "H2". 5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced. 6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance. 7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed. If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ element test bake broil with meter-undefined-undefined-0_3.jpg fuse module with words-undefined-undefined-1_0.jpg fuse oven fuse location3-undefined-undefined-2.jpg fuse location oven fuse_ranger_17-undefined-undefined-3.jpg infinte switch_noheat_03-undefined-undefined-4.jpg oven thermostat location2-undefined-undefined-5_0.jpg relay board gas relat board-undefined-undefined-6.jpg
7/23/2023 11:26:22 PM • Jenn-Air Ovens • Answered on Jul 23, 2023
How do I replace an infinite burner switch in a Jenn Air S156?
This shows a screw under the outer edges. https://www.partswarehouse.com/Jenn-Air-S156-Range-s/353129.htm https://www.google.com/search?q=fit+part+W11120791 Service Manual
Jenn-Air Electric Range Service Manual
Step Right Up Manuals https://new2.steprightupmanuals.com > product > jenn... Download Jenn-Air Electric Range Service Manual for Models D140, D146, D156, S100, S101, S105, S110, S120, S121, S124, S125, S136, S156, S160, S161, S166, ... US$8.99 Generic Jenn Air video, different model
6/6/2023 3:43:40 AM • Jenn-Air Ovens • Answered on Jun 06, 2023
Jenn-Air WW30430P Oven -
It is all electronic and also has touch sensors and relays. Here is the Service Manual to give you an overview, but you will need a Service call.
Jenn-air WW30430P Manuals
ManualsLib https://www.manualslib.com > ... > Oven We have 6 Jenn-Air WW30430P manuals available for free PDF download: Service Manual, User Manual, Use And Care Manual. Jenn-Air WW30430P Service Manual (51 ... ...
4/1/2023 10:48:31 PM • Jenn-Air Ovens • Answered on Apr 01, 2023
2answers
JennAir Wall Oven. The broiler element comes on when baking!
Question edited for clarity and typo. Question moved to Jenn-Air. It is a known iss. The fix is here. You need a relay board. https://www.justanswer.com/appliance/7apwg-jenn-air-oven-turns-broil-element-when-using.html https://www.google.com/search?q=JennAir+Wall+Oven.+The+broiler+element+comes+on+when+baking ..
9/19/2022 5:56:27 PM • Jenn-Air Ovens • Answered on Sep 19, 2022
Jenn-Air JJW9830D Electric Double Oven Logo
13 questions posted
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Ovens
  • Jenn-Air Ovens
Most Popular Question
jenn air jjw9830ddp double oven
  • Ovens
