Oven stops working after a few minutes and shuts itself off. Display on LED is F760.
Hello. The error code refers to a defective keypad. I will absolutely need the entire model number(ex JS968BF1BB thru 6BB, JS968BK1BB thru 5BB, JS968KF1CC thru 6CC, JS968KK1CC thru KK5CC, JS968SF1SS thru SF6SS), and there are a few more model series.
The part mounting, etc. is basically the same--HOWEVER, depending on the model, the part number is different. (example JS968BF1BB touch panel is WB27T10439. JS968BK1BB touch panel is WB27T10751 and so on). Just looking on the net, I saw prices for this part in the neighborhood of +/- 200.00. Shop carefully for the best price--If you are hesitant about replacing the panel yourself, DEFINITELY CALL FOR SERVICE. Your range has several microprocessor controlled boards. I have replaced a fair amount of them--and no, they aren't bad or anything like that either. If you're going to do it yourself, take pix as you go, make a diagram if needed for the screw locations, etc. ALWAYS REMOVE POWER FROM THE RANGE BEFORE TOUCHING YOUR TOOLS AND STARTING WORK!! I hope I helped you!
SOURCE: F4 code when preheating oven
That code means "Shorted Oven Sensor". You can find out more about this by removing the bottom drawer, pull it out til it stops, lift it up and pull it all the way out. Now lay down on the floor and look under the oven to the left side. You will see a service info card there. Pull it out, open it up and have a read.
SOURCE: GE Spectra Oven not working
What is "the board"? and is this replaceable by a fairly competent user or does this require a service call? Thanks!
SOURCE: ge oven profile spectra xl44
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
Why do you need to do this?
If the door lock is stuck in closed position and preventing you from using the range?
You may free this by following this procedure.
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects most problems!.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the lock switch itself is bad and if you think you can bypass it then you may as well change it. Same labor!!.
Let me know how it works out.
Huuum
Please remember to leave a rating.
SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
