20 Most Recent
GE Profile JGB900 Gas Kitchen Range Questions & Answers
JGB900 oven won't work. Range
Your problem is with the oven ignitor.
Remove the racks from the oven, remove bottom shelf. Remove the metal plate covering flame spreader. The igniter should now be visible. Turn oven on and watch the glow from the igniter. It will come on but it wouldnt get too bright, so it wouldnt open the gas valve. After changing the ignitor, oven should light.
My ge gas range wont work on BAKE but everything
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one.
I am getting a message ERR when i press bake and
Hi,i think you are trying to bake with a temperature higher than what is required by your gas kitchen range,perhaps,Somehow your oven is set to cook in Celsius instead of Fahrenheit.
To switch back to Fahrenheit open the oven door, then press and hold BROIL for 5 sec or until "F°" will appear on the display.you are good to go.
if this doesn't wok,please give me the detailed,exact error message,so i can help you out.
Thanks and take care
The door is open and
HI. The door locking mechanism will be the culprit, here. In order to confirm the damage, you will need to gain access to the actual mechanism. Once you have exposed the locking mechanism, pay close attention to the actual circuit section of the mechanism. The contacts will be used for the testing procedure. You will need to inspect the wiring at the locking mechanism. make sure that it is connected to the main PCB, properly. One of the most common causes for this particular issue will be connection failure, due to a slight separation at the contacts. This separation can occur overtime. at the control board, or locking mechanism. Once the connection is severed, the locking mechanism will stall. The connections at the control and locking mechanism should be tight, with no corrosion, as well. Check the insulation around the wires for faults. If the connection to and from the control is optimal, this will lead to the actual door locking mechanism. Use the procedure below to test the circuit functionality.
DOOR LOCKING MECHANISM TEST:
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
GE gas range, model #jgbp33wen5ww, ignitors
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Oven shows F7 and continues to beep
This almost always requires replacing the touch key panel. Once in a great while you can avoid replacement by disconnecting the ribbon connector from the key panel to the electronic range control and cleaning the end of the ribbon connector with a soft pencil eraser. Good luck.
