I am looking to download a manual for the motherboard connections
SOURCE: Asrock 775 vmb Motherboard
Sorry randar, I need more information about the board. You can look here at Asrock's link.
http://www.asrock.com/support/download.asp?c=775
This pade shows all their Socket 775's.
Now you understand why I asked for more info!
SOURCE: ECS RC415ST SKT 775 MOTHERBOARD MANUAL
RC415ST is a HP Motherboard Model. please check the model again
SOURCE: motherboard GA-8I86GME-775-RH
Leon, this may be the sight you wanted.
If you were searching for the drivers (googling etc) you may not have found them as your model number of the mobo was missing a number.
try here:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2274
Keep us informed if this was what you were after or not.
**.The best way to acknowledge contribution is to rate it's relevance.**
SOURCE: i was using my asrock G31M-S destop when it went off. now when i
The power supply might be bad, or you might be drawing too much current due to a short elsewhere. If you can get your hands on a compatible power supply, I'd try that first. You can unhook plugs to try to pinpoint a short (in a CD, DVD player, etc. Get an estimate on an estimate from a computer shop, in case all else fails.
Testimonial: "it worked perfectly. you are a genius."
