20 Most Recent Asrock K8NF4G-SATA2 Motherboard Questions & Answers
0answers
Jumper settings
Be the first to answer 9/22/2013 7:17:36 AM • Asrock... • Posted on Sep 22, 2013Be the first to answer
Tried to upgrade memory on Asrock K8NF4G-SATA2 to 2 X 1Gb modules. With one module fitted PC starts and shows 1Gb. With 2 fitted it will not start. Tried both modules one at a time in slot 0 and board
Hello here is the homepage:http://www.asrock.com/mb/NVIDIA/K8NF4G-SATA2/I think the second slot for the ram might have a defect.The problem could also be a bios setting or an update.The bios can be upgraded while the system is running.If you are in doubt upgrading the bios let a expert do this for you.Remember that dust can make a bad connection and do not touch the contact points with your fingers.Try to buy a can with compressed air and blow the ram slot out for dust.The ram modules must sometimes be at equal size (mhz) in order to the mainboard can boot with the ram.Good luck
12/20/2012 2:09:11 PM • Asrock... • Answered on Dec 20, 2012
K8NF4G MOTHERBOARD IS NOT WORKING
Your Video Card (Graphics Card) is probably bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays the same NO Signal Message then your video card is bad. If the Borrowed monitor displays and works correctly, then your original monitor is bad. The fact that your monitor displays the No Signal Message on it shows that the monitor is ok.If you have a laptop, the video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
5/31/2012 11:58:10 AM • Asrock... • Answered on May 31, 2012
I need K8NF4-SATA2 lan driver
Hello tcs_1448, go to this "Website," and "Fill-in" or {Choose}
any information needed to get the "Drivers" you need.
Than you'll be able to "Download the Drivers."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://www.asrock.com/support/download.asp?cat=Drivers
2/16/2011 5:24:12 AM • Asrock... • Answered on Feb 16, 2011
2answers
Cannot connect internet
hi,
install the network driver package included in your motherboard.
2/16/2011 5:22:23 AM • Asrock... • Answered on Feb 16, 2011
ASRock K8NF4G-SATA2 motherboard with on board
It seems that you have the incorrect driver installed. Safe mode uses a generic driver designed to work with all graphics cards. According to the documentation for your motherboard, it should have came with a drivers disk. The driver should be on there. If it isn't it will be here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
If this does not resolve the issue. I would verify that it is, in fact, an NVidia GeForce 6100. The only way to know this for sure, is to remove the heatsink from the GPU (the silver colored one in the middle) and find the Manufacturer's insignia on the chip itself. Be carefull not to damage the chip and replace the heat sink gel when you reseat the heat sink.
10/28/2010 11:25:45 PM • Asrock... • Answered on Oct 28, 2010
ASRock K8NF4G-SATA2 cannot sound, Problem
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
10/27/2010 3:34:20 AM • Asrock... • Answered on Oct 27, 2010
I have this problem... when i disconnect power
motherboard is bad
4/23/2010 9:52:11 AM • Asrock... • Answered on Apr 23, 2010
My computer with Windows XP Pro SP2 is crashing
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
11/13/2009 3:46:19 PM • Asrock... • Answered on Nov 13, 2009
3answers
THIS MOTHERBOARD SUPPORT PROCESSORS WITH 2 CORS
http://www.asrock.com/mb/cpu.asp?Model=K8NF4G-SATA2
looks llike you can put an amd Sempron-64bit cpu in.
10/13/2009 9:17:27 AM • Asrock... • Answered on Oct 13, 2009
After 10 mins OR 10 hours the display completely
Could be heat issue try install an extra fan on your case check graphics card temp with a freware program and check the temps are normal
http://www.almico.com/speedfan.php
8/2/2009 10:49:04 AM • Asrock... • Answered on Aug 02, 2009
I bought this Motherboard because my nephew said
This link will take you to your manual. Good luck. http://download.asrock.com/manual/K8NF4G-SATA2.pdf
6/26/2009 12:53:20 AM • Asrock... • Answered on Jun 26, 2009
TOLD TO DOWNLOAD FOR A FRIEND A SOUND /DRIVE
Look Here
Are you sure that number is right? Should that R be a 6?
Please vote if you find this information helpful.
Thank You
4/24/2009 7:19:33 AM • Asrock... • Answered on Apr 24, 2009
I don't have a video card in my K8NF4G-SATA2
you need a video card or most called now graphic cards you need ram always in your computer you cant have a computer without (ram)
4/19/2009 7:48:45 PM • Asrock... • Answered on Apr 19, 2009
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
5/7/2022 4:02:49 PM • Asrock Computers... • Answered on May 07, 2022
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
5/7/2022 3:59:28 PM • Asrock Computers... • Answered on May 07, 2022
3answers
No display on my Asrock P4I45GV
Check Ram and fun if not properly installed
5/7/2022 2:12:39 PM • Asrock Computers... • Answered on May 07, 2022
2answers
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO. If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
5/7/2022 1:13:35 PM • Asrock Computers... • Answered on May 07, 2022
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo and all 3 same reasons. and all 3 same answers. zero no I added one, coin cell is dead at 7 years, you are 2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
12/29/2021 4:42:52 PM • Asrock Computers... • Answered on Dec 29, 2021
Asrock K8NF4G-SATA2 Motherboard Logo
20 questions posted
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Asrock Computers & Internet
Most Popular Question
tried upgrade memory asrock k8nf4g sata2
  • Computers & Internet
