Fantom Vacums Lighting Canister Vacuum Logo
Posted on Oct 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wand for beater bar
I have a Fantom canister Model BPSRLC5101 Style LC2. I broke the wand and need a replacement for it. I live in Calgary
CJ C
Level 2:
Scholar:
  • Expert 66 Answers
  • Posted on Nov 30, 2008
CJ C
Expert
Level 2:
Scholar:
Answers
66
Questions
0
Helped
45598
Points
113
2answers
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
3answers
There is no power to my Filter Queen power nozzle. I have cleaned the connection and there is still nothing.
There is an electrical connection at the canister end and again at the beater end. If the beater is not working it is mostly that this is where you problem is. You need to test first to see if there is power at the canister end and then at the beater end. If there is no power at the canister it could be the outlet or something internal. If there is no power at the beater end then that outlet, or the cord could be the problem. If you have power and that end then the problem is likely within the wiring in the beater or in the motor itself
There seems to be a short between the canister and the extension wand hookup. Right at the plug between located at the front of the canister and where the extension wand plugs in. When you rotate the...
Well, Anthony, considering as how I have no idea of what brand, make, model or color your vac is, I can't make much of a guess as to why it doesn't work. We'd need more info if you want to log back on at a later date, such as brand, model, maybe even a picture of the unit so we could see just where your problem might be.
Oct 22, 2013 • Vacuums
2helpful
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
4helpful
3answers
Same issue...need replacement wand for fantom lightning
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
7helpful
4answers
Need new powerhead for Fantom Lightning Style PH1A - Where can I buy it and how much?
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested.
7helpful
3answers
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Top Fantom Vacums Vacuums Experts
john h
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
